Cisco 892 Packet loss on Vlan interface
gwijnants
Hi all,
We have a Cisco 892 and we are experiencing some performance issues.
When testing using Iperf from LAN to WAN with speeds of 750Mbit/sec (packet size 1024K) we see packet loss when pinging the LAN ip address (Vlan 100) of the router.
I was told the throughput would be around 1.6Gbps.
Below the config of the router. Any help on how to enhance the performance?
Best Regards,
Guy
! Last configuration change at 13:59:49 UTC Mon Jul 31 2023 by syntigo
version 15.4
hostname Router
boot-start-marker
boot system flash:c800-universalk9-mz.SPA.154-3.M3.bin
boot-end-marker
aqm-register-fnf
logging buffered 65536 informational
no aaa new-model
memory-size iomem 25
ip cef
no ipv6 cef
cts logging verbose
license udi pid C892FSP-K9 sn FCZ214992FF
username cisco privilege 15 secret 5 $1$mWFD$bAdqxlwLF8fIY6Ug1xz.U/
interface GigabitEthernet0
 description LAN1
 switchport access vlan 100
 no ip address
interface GigabitEthernet1
 description LAN1
 no ip address
interface GigabitEthernet2
 description *** unused ***
 no ip address
 shutdown
interface GigabitEthernet3
 no ip address
 shutdown
interface GigabitEthernet4
 no ip address
 shutdown
interface GigabitEthernet5
 no ip address
 shutdown
interface GigabitEthernet6
 no ip address
 shutdown
interface GigabitEthernet7
 no ip address
 shutdown
interface GigabitEthernet8
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet9
 description WAN
 ip address 1.1.1.1 255.255.255.252
 duplex auto
 speed auto
interface Vlan1
 no ip address
 shutdown
interface Vlan100
 description LAN1
 ip address 2.2.2.254 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 1.1.1.2
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner motd ^C^C
line con 0
 exec-timeout 5 0
 login local
 no modem enable
line aux 0
 access-class 2 in
 exec-timeout 5 0
 login local
line vty 0 4
 exec-timeout 5 0
 login local
 transport input all
line vty 5 15
 exec-timeout 5 0
 login local
 transport input all
scheduler allocate 20000 1000
ntp access-group peer 10
ntp access-group serve-only 11
ntp access-group query-only 11
ntp server time.google.com
end
9 Replies 9
Mark Elsen
 - Use latest advisory software version for the 892 ; check if that can help ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
show interface g0 and g1 <<- share this
Joseph W. Doherty
Who told you throughout should be 1.6Gbps?
What do the CPU stats look during this test?
Hi @gwijnants
  I attached a document where they run very interesting tests on this router and I believe this can be useful for you. But I believe your expectation for this router is a bit high.
Interesting results, but limited by using interfaces running at only 100 Mbps. (?)
I've attached a Cisco white paper, which also measures 890 series throughtput performance under various conditions.
Table 1 shows a max throughput rate of 1.4 Gbps for 1500 byte packets.  As this particular test, appears to be the best possible throughput rate, reason I asked about source of 1.6 Gbps possible for 1K sized packets.
At the end of this Cisco white paper, Cisco only recommends (see figure 1) the 890 series for WANs circuits supporting up to 15 Mbps (that would be for duplex).
Much like Flavio's reference, this Cisco white paper shows impact of packet size and services.
Software based routers, are generally limited by the performance/capacity of their CPU (which is why I also asked about CPU stats during the test).
Pinging the router, itself, will also consume its CPU.
Hi all,
Thank you so much for the help already.
About the 1.6Gbps I found the info on the Cisco Forum somewhere.
When testing with Iperf and doing 1 stream of 1Gbps I have no packet loss when pinging the LAN (vlan 100) gateway from the LAN client. When doing for instance 4 streams of 250Mbit I have packet loss. All using Frame size of 1500.
CPU load using 4 streams of 250Mbit
Router#sh processes cpu history
Router   09:37:08 AM Tuesday Aug 1 2023 UTC
      333333333333333333333333333333333333333333333333333333333333
      444888885555544444555554444455555555558888833333444443333355
  100
   90
   80
   70
   60
   50
   40    **********     *****     ***************               **
   30 ************************************************************
   20 ************************************************************
   10 ************************************************************
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
Router#
Interfaces output
Router#sh int gi9
GigabitEthernet9 is up, line protocol is up
  Hardware is PQ3_TSEC, address is 005d.7326.1c51 (bia 005d.7326.1c51)
  Description: WAN
  Internet address is 1.1.1.1/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 165/255, rxload 1/255
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 125310
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 3661000 bits/sec, 7584 packets/sec
  5 minute output rate 648808000 bits/sec, 53585 packets/sec
     10261262 packets input, 621444604 bytes, 0 no buffer
     Received 10171 broadcasts (0 IP multicasts)
     0 watchdog, 9 multicast, 54459 pause input
     72783142 packets output, 110154696794 bytes, 0 underruns
     8 unknown protocol drops
     1 lost carrier, 0 no carrier, 0 pause output
Router#sh int gi0
GigabitEthernet0 is up, line protocol is up
  Hardware is Gigabit Ethernet, address is 005d.7326.1c3f (bia 005d.7326.1c3f)
  Description: LAN1
     reliability 255/255, txload 1/255, rxload 167/255
  Full-duplex, 1000Mb/s
  Last input 00:13:46, output never, output hang never
  5 minute input rate 654980000 bits/sec, 53950 packets/sec
  5 minute output rate 3934000 bits/sec, 7658 packets/sec
     73144774 packets input, 111005224199 bytes, 0 no buffer
     Received 471 broadcasts (1350 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     10279741 packets output, 660173999 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     2 unknown protocol drops
Router# sh int vlan 100
Vlan100 is up, line protocol is up
  Hardware is EtherSVI, address is 005d.7326.1c3e (bia 005d.7326.1c3e)
  Description: LAN1
  Internet address is 2.2.2.254/24
  Keepalive not supported
  Last input 00:00:00, output never, output hang never
  5 minute input rate 658711000 bits/sec, 54402 packets/sec
  5 minute output rate 3377000 bits/sec, 7755 packets/sec
     73765710 packets input, 111654175313 bytes, 0 no buffer
     Received 1344 broadcasts (0 IP multicasts)
     10385959 packets output, 565021337 bytes, 0 underruns
     0 output errors, 1 interface resets
     465 unknown protocol drops
Router#
Is the overhead to big?
Best Regards,
Guy
You CPU stats looks good, as CPU appears to not be overloaded.
Your WAN interface shows drops.  As you have two active LAN interfaces, you can overrun your WAN interface.  It might help to increase the queue size for the WAN interface.  (40 is pretty small for a gig interface.)
Would suggest, you clear interface stats at beginning of a test, and see what stats are at the end of the test.  (You can see if drops decrease as you increase egress queue size.  Try, 64, 128, 256, 512, 1024.  Once drops appear to dramatically drop, don't increase further.)
You might also reduce your interface load average counters to the minimum value of 30 seconds.
Really like to better understand exactly what you're doing.
You're using iPerf to generate with 1 stream or 4 streams, both now (earlier you were using 1K size?) using 1500 bytes packets, from LAN to WAN, correct?  UDP or TCP?  Destination of the stream(s)?
Whether 1 stream or 4, you get about the same max throughput, correct?
While iPerf test is running, if you're only using 1 stream, you can ping the LAN interface (from LAN port?) without ping drops, but when running 4 streams you see ping drops, correct?
So far, not seeing a glaring problem that would explain your ping issue.
Do keep in mind, Cisco network devices deal with pings as a low priority function and will sometimes consider a bunch of pings as a DoS attack and just not respond to some of the pings.  (Cannot say that's what's happening here.)
I also looked up your IOS version, 15.4.3M3.  It's 8 years old and an ED release, M4 and later are MD,.  The last release, in that train, was 15.4.3M10.  I would suggest updating to that version, if you can, or consider updating to one of the two releases Cisco recommends:
Lastly, if you're ping the router, suggest you, instead, ping something "though" the router, to determine if transit traffic is being impacted.
Hi Joseph,
Thank you for your feedback, much appreciated.
I understand your feedback regarding the WAN interface but the problem already persists on the LAN side.
When I have a laptop on the LAN side sending 4 streams of 250mbit each the laptop has ping loss when pinging its default gateway (2.2.2.254). With 1 stream of 1Gbps there is no ping loss.
I know Cisco deals with pings as low priority, but is this only for its own interfaces or also ping towards external ip adresses (8.8.8.8 for example).
All testing of iperf has been done using packet size 1500 TCP.
To increase the queue size (I think its the number of packets?)
I use following config?
policy-map Queue-size
 class 1
   queue-limit 512
   random-detect
and then link it to the interface.
Pinging destinations through the router also gives ping loss.
Best Regards,
Guy
On its "face", unclear why 4 streams of 250 Mbps would cause ping drops when a single stream of 1 Gbps does not.
Are the iPerf streams always sourced from the same laptop?
If so, there's many factors that can cause this difference, including how accurately or how exactly your laptop generates four 250 Mbps streams vs. a single gig stream.  Especially if they're doing TCP rather than UDP streams.
Although your question/concern is valid, getting to the bottom of the root cause of what you're seeing, might be very time consuming, and may lead to an explanation (unfortunately) that's "just the way it works" i.e. expected behavior.
Heck, even how iPerf works, can be factor.  There's a reason why when you read professional network device performance reviews they use specialized test equipment.
Or, further consider, is what you're seeing even causing a real issue with your real "normal" traffic?
Cisco's recommendation for the 890 series, they're suitable for handling WAN links up to 15 Mbps for almost any situation, and in specific "usual" usage cases, their highest throughput listed was only for 64 Mbps (aggregate).
So what is your actual goal?  You "need" no ping loss when pushing around 750 Mbps, using multiple flows?
Personally, I actually find why you're obtaining the results you're obtaining, interesting (and truly would like to know the "why), but unsure it's interesting enough to be worth my time.  Is it worth your time?
Any way, to your question about how to increases the WAN interface's egress queue size, I had in mind the interface hold-queue # out command.
If you want to try a CBWFQ policy, perhaps:
 class class-default
   queue-limit #
   random-detect
!or
 class class-default
   fair-queue
interface g#
 service-policy output Queue-size
