Cisco 892FSP router basic config
alficho23
Hi all,
Please help me with the below configuration, i`m stuck on basic routing for last two days.
End users get dhcp, but no internet access - any guidance will be much appriciated.
Building configuration...
Current configuration : 1817 bytes
! Last configuration change at 22:05:15 UTC Mon Mar 6 2023
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip dhcp excluded-address 10.20.10.1 10.20.10.30
ip dhcp pool LAN-TRUNK
network 10.20.10.0 255.255.255.0
default-router 10.20.10.1
dns-server 1.1.1.1 8.8.8.8
ip cef
no ipv6 cef
license udi pid C892FSP-K9 sn xxxxxxxx
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
switchport access vlan 103
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet9
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 10.20.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Vlan1 overload
ip route 0.0.0.0 0.0.0.0 10.10.10.1
access-list 1 permit 10.20.10.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
ip nat inside source list 1 interface Giga8 overload
this missing
10 Replies 10
4 Questions:
1. Are devices being NAT'd - after the device attempts to reach the internet are they being put in the local NAT table?
show ip nat
2.  does the internet have a route back to your network. You have a default route out but you need routing for return traffic as well
3. Your default route points to
10.10.10.1
Can you reach it (ping)?
4.  Is your
Gig8 interface
getting an IP address?
-David
Hi David,
1)
 Router#show ip nat translations
Pro Inside global Inside local Outside local Outside global
udp 10.20.10.1:49882 10.20.10.31:49882 1.1.1.1:53 1.1.1.1:53
udp 10.20.10.1:49882 10.20.10.31:49882 8.8.8.8:53 8.8.8.8:53
udp 10.20.10.1:50534 10.20.10.31:50534 8.8.8.8:53 8.8.8.8:53
udp 10.20.10.1:51434 10.20.10.31:51434 1.1.1.1:53 1.1.1.1:53
udp 10.20.10.1:51434 10.20.10.31:51434 8.8.8.8:53 8.8.8.8:53
udp 10.20.10.1:51482 10.20.10.31:51482 1.1.1.1:53 1.1.1.1:53
udp 10.20.10.1:51482 10.20.10.31:51482 8.8.8.8:53 8.8.8.8:53
udp 10.20.10.1:51961 10.20.10.31:51961 1.1.1.1:53 1.1.1.1:53
udp 10.20.10.1:51961 10.20.10.31:51961 8.8.8.8:53 8.8.8.8:53
udp 10.20.10.1:52178 10.20.10.31:52178 1.1.1.1:53 1.1.1.1:53
udp 10.20.10.1:52178 10.20.10.31:52178 8.8.8.8:53 8.8.8.8:53
udp 10.20.10.1:52899 10.20.10.31:52899 1.1.1.1:53 1.1.1.1:53
udp 10.20.10.1:52899 10.20.10.31:52899 8.8.8.8:53 8.8.8.8:53
udp 10.20.10.1:53646 10.20.10.31:53646 1.1.1.1:53 1.1.1.1:53
udp 10.20.10.1:53646 10.20.10.31:53646 8.8.8.8:53 8.8.8.8:53
udp 10.20.10.1:54568 10.20.10.31:54568 1.1.1.1:53 1.1.1.1:53
udp 10.20.10.1:54568 10.20.10.31:54568 8.8.8.8:53 8.8.8.8:53
tcp 10.20.10.1:54765 10.20.10.31:54765 52.114.74.222:443 52.114.74.222:443
tcp 10.20.10.1:54774 10.20.10.31:54774 13.69.239.73:443 13.69.239.73:443
udp 10.20.10.1:55337 10.20.10.31:55337 1.1.1.1:53 1.1.1.1:53
udp 10.20.10.1:55337 10.20.10.31:55337 8.8.8.8:53 8.8.8.8:53
2) No i have not set route back
3) Yes without any problem
4) Yes it gets ip address from my pfsense router
I thought it would be a good idea to learn on cisco equipment, therefore deployed 892fsp in my home lab.
Thanks for your quick reply David
balaji.bandi
As per the config on the router - if you getting DHCP IP outside interface as you configured, then you need to change below and test it :
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip nat inside source list 1 interface Vlan1 overload
ip nat inside source list 1 interface gig8 overload
no ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip route 0.0.0.0 0.0.0.0 gig8 dhcp
still not working
post new config
show run
show IP interface brief
show IP route
BB
alficho23
Hi guys still not working, new config as follow:
Router#show running-config
Current configuration : 1775 bytes
! Last configuration change at 23:04:55 UTC Mon Mar 6 2023
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip cef
no ipv6 cef
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip http server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
Router#show IP interface brief
GigabitEthernet0 unassigned YES unset up up
GigabitEthernet1 unassigned YES unset down down
GigabitEthernet2 unassigned YES unset down down
GigabitEthernet3 unassigned YES unset down down
GigabitEthernet4 unassigned YES unset down down
GigabitEthernet5 unassigned YES unset down down
GigabitEthernet6 unassigned YES unset down down
GigabitEthernet7 unassigned YES unset down down
GigabitEthernet8 10.10.10.89 YES DHCP up up
GigabitEthernet9 unassigned YES unset administratively down down
NVI0 10.10.10.89 YES unset up up
Vlan1 10.20.10.1 YES manual up up
Router#show IP route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is 10.10.10.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.10.10.1, GigabitEthernet8
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 10.10.10.0/24 is directly connected, GigabitEthernet8
L 10.10.10.89/32 is directly connected, GigabitEthernet8
C 10.20.10.0/24 is directly connected, Vlan1
L 10.20.10.1/32 is directly connected, Vlan1
this missing
Correct all working now.
Thanks a lot
I own you a beer
i do not see NAT config :
how are you testing, on what port the device is connected.
if the below port you using to test, this port belong to VLAN 103 (and you have layer 3 interface vlan 1) - so you need to change to vlan 1 to work.
no ip address
End device what IP address you getting ? or you not getting any IP address ? (if you are not getting any IP address then that is is cause of VLAN config issue correct it.
Testings from router :
1. start ping from router 8.8.8.8 (is this working ?)
2. what is the IP address PC getting ?
3. ping from PC to Gateway 10.20.10.1 ? is this working ?
4. ping from PC to 8.8.8.8 is this working ?
BB
@MHM Cisco World  advised missing
all works now
Good, you were able to resolve the issue - the advice was suggested in the first instance of my reply post to make necessary changes to work (looks like that was ignored in this instance i guess ).
BB
No not at all ignored, it is my first cisco device for testing purposes only.
I did not fully understood you advice, neverthless many thanks for all your help.
