Configuring a router for first time
npranger
Hello,   first attempt to completely configure a router (2911) with CLI.  I am asking the community to review my confguration script.
Topology:  The church will have a single 2911 router.  Router port 0/0 will have 4 subinterfaces, 1 for each vlan.  A trunk port will connect to the router to a 2960 Cisco switch.  Three Cisco 1830I access points will be connected to the switch.
  • Project goals:  1) Reliable connectivity through most the cinder block building.  2) Security of the business information. 4) Low budget project due to lack of funding.
Vlans:  Staff WIFI  on vlan 10   192.168.10.0/24.    Guest WIFI on vlan 30   192.168.30.0/24.   Management on vlan 90 192.168.90.0/24.  Native vlan 100 192.168.100.0/24
Configuration script for a 2911 router.  Please review - give comments.
  Questions:  With this setup.  Did I configure a trunk coming out of the router?  Do I need to name the vlans in the router like I do on a switch?
Configure UMC gigabit ethernet router script
! Basic setup
>enable
# hostname UMCrouter
# enable password UMCrouter#1
#configure terminal
Config# no ip domain-lookup
Config# interface gigabitethernet 0/0
Config-if# cdp enable
Config-if# no ip address
Config-if# duplex auto
Port-tagging
Encapsulation dot1q 10
Set cos 6
Config-if# no shutdown
Config-if# exit
Internet setup
>enable
# show ip interface brief
# configure terminal
Config# Interface gigabitethernet 0/0
Config-if# ip address 12.34.56.2 255.255.255.0
Config-if# interface gigabitethernet 0/1
Config-if# ip address 192.168.1.1 255.255.255.0
Config-if# C^Z
# show ip route           no default route
! Create default route in routing table
#configure terminal
Config# ip route 0.0.0.0 0.0.0.0 12.34.56.1
# show route
#ping 8.8.8.8   computer ping internet
! Link inside ip addresses to internet including all vlan addresses
#configure terminal
Config# ip access-list extended internet_ACL
Config-ext-nacl# permit ip 192.168.1.0 0.0.0.255 any
Config-ext-nacl# permit ip 192.168.10.0 0.0.0.255 any
Config-ext-nacl# permit ip 192.168.30.0 0.0.0.255 any
Config-ext-nacl# permit ip 192.168.90.0 0.0.0.255 any
Config-ext-nacl# permit ip 192.168.100.0 0.0.0.255 any
Config-ext-nacl# exit
! Configure NAT
Config# ip nat inside source 1
Config# ip nat inside source list internet_acl interface gigabitethernet 0/1
Config# interface gigabitethernet 0/1
Config-if# ip nat outside
Config-if# interface gigabitethernet 0/0
Config-if# ip nat inside
! at this point inside PC should be able to ping internet
!  create SSH access
>enable
#configure terminal
Config# ip domain-name UMC.local
Config# crypto key generate rsa
            How many bits in the modulus;   4096
Config# ip ssh version 2
! Hostname has been set prior
! Disable telnet
Config# line vty 0 98
Config# transport input ssh  echo-reply
! Limit remote access from cyberattacks
Config# ip access-list extended outside filter
Config-ext-nacl# Permit icmp any host 12.35.56.2 echo-reply
Config-ext-nacl# permit udp any eq domain host 12.34.56.2
Config-ext-nacl# permit 12.34.56.2 established
Config# C^Z
Config-if# ip access-group outside filter inside filter
Config-if# C^Z
#copy running config startup config
! Configuring ROAS interface G0/2
  Enable
Config# interface gigabitethernet 0/2 and subinterfaces
Config-if# port tagging
Config-if-port-tagging# encapsulation dot1q 10
Config-if-port-tagging# set cos 6
Config-if-port-tagging# exit
Config-if# C^Z
#show run interface g0/2
! use ping
#configure terminal
Config# interface gigabitethernet 0/2.10
Config-if# description vlan for work staff wifi
Config-if# encapsulation dot1q 10
Config-if# encapsulation dot1q 100 native
Config-if# ip address 192.168.10.4 255.255.255.0
Config-if# exit
Config# ip dhcp pool vlan10
DHCP-config# network 192.168.10.0 255.255.255.0
DHCP-config# default-router 192.168.10.1
DHCP-config# dns-server 8.8.8.8
DHCP-config# ip dhcp excluded-address 192.168.10.1 192.168.10.20
Config-if# exit
Config# interface gigabitethernet 0/2.30
Config-if# description vlan for guest wifi
Config-if# encapsulation dot1q 30
Config-if# ip address 192.168.30.4 255.255.255.0
Config-if#ip dhcp pool vlan 30
DHCP-config# network 192.168.30.0 255.255.255.0
DHCP-config# default-router 192.168.30.1
DHCP-config# ip dhcp excluded-address 192.168.30.1 192.168.30.20
Config# interface gigabitethernet 0/2.90
Config-if# description vlan for management of network
Config-if# encapsulation dot1q 90
Config-if# ip address 192.168.90.4 255.255.255.0
Config-if# ip dhcp pool vlan90
DHCP-config# network 192.168.90.0 255.255.255.0
DHCP-config# default-router 192.168.90.1
DHCP-config# ip dhcp excluded-address 192.168.90.1 192.168.90.20
Config-if# exit
Config# interface gigabitethernet 0/2.100
Config-if# description vlan for native traffic
Config-if# ip address 192.168.100.4 255.255.255.0
Config-if# ip dhcp pool vlan100
DHCP-config# network 192.168.100.0 255.255.255.0
DHCP-config# default-router 192.168.100.1
DHCP-config# ip dhcp excluded-address 192.168.100.1 192.168.100.20
DHCP-config# C^Z
Thanks, Phil
5 Replies 5
Richard Burts
You asked a few specific questions and here are my responses:
" Did I configure a trunk coming out of the router" the subinterfaces configured should allow the router to process the trunk connection to the switch.
"Do I need to name the vlans in the router " No you do not need to name the vlans on the router.
I believe that the script as posted is more complicated than it needs to be. Here are some comments:
- multiple times you are in config mode, then you exit config mode, execute some commands, go back into config mode. Why not just use the do show ip interface brief and stay in config mode?
- there is a mismatch between what you describe " Router port 0/0 will have 4 subinterfaces" and the config that puts the subinterfaces on 0/2.
- you show these commands after entering enable mode
But both of these would be entered in global config mode (after you enter configure terminal)
- under G0/0 you use "Encapsulation dot1q 10" which matches your description but conflicts with what you actually do to put vlan 10 on G0/2.
- under G0/0 you configure no ip address, exit config mode, enter config mode and assign an IP address. Why do all that?
- you configure acl internet_ACL. But when you use it for NAT you change the case of the name
I strongly suggest that for NAT you use a standard acl and not an extended acl which specifies any as the destination. I have seen situations were that causes problems.
- on an interface with a private address you call it nat outside
and on interface with public IP you call it nat inside
- on the vty where did echo-reply come from? "Config# transport input ssh echo-reply"
- your Internet acl is way too restrictive. And you apply it to the wrong interface
- you put this under subinterface 0/2.10 but it should go under subinterface 0/2.100
- on each subinterface you give it an address and then in the associated dhcp pool you specify that the default router is a different address. For example
But in the dhcp pool you say that the default router is 192.168.10.1. The default router should be the router interface address.
Rick
Rich,  thank you so much for the time you spent outlining your answer.  I will study the response and work on it.  Very kind of you
Phil
Phil
You are welcome. I Would like to follow up on part of my response to the original post. The various steps you include to check the results of config commands is a nice idea, and as you get closer to actual implementation they may be appropriate. But in these early stages where you are trying to understand how things work I am concerned that trying to check results is a distraction from your primary focus which is on producing a configuration that works.
Rick
Thank you for the feedback.
Get Outlook for Android<>
balaji.bandi
high level that should work if the respected interface connected to switch correctly
i have guided other post what you looking to do. (if you have any issue post how the Router connected to switch and ISP in a small diagram) - post show run (what is the issue you encountering ?)
https://community.cisco.com/t5/routing/router-892fsp-subinterfaces/td-p/4783462
BB
