Cisco 897 ACL issue - block incoming traffic
I am facing an issue which I can't get my head around.  I would like to limit inbound traffic from the outside interface i.e. the WAN.  I have created an ACL and applied it to the WAN interface inbound.  However whenever I apply it, the ACL seems to works but all outbound traffic gets blocked too.
here is my config - any pointers would be much appreciated and I guess i'm missing something obvious!
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface Ethernet0
 no ip address
 shutdown
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
interface GigabitEthernet8
 ip address 1.1.1.1 255.255.255.248
 ip access-group outside_access_in in
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no cdp enable
interface Wlan-GigabitEthernet8
 no ip address
interface wlan-ap0
 no ip address
interface Vlan1
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 9.9.9.9
ip ssh port 2222 rotary 1
ip access-list extended ACL-CONSOLE-PERMIT
 permit ip 3.3.3.3 0.0.0.255 any
 permit ip 4.4.4.4 0.0.0.255 any
 deny   ip any any
ip access-list extended outside_access_in
 permit icmp any any time-exceeded
 permit icmp any any unreachable
 permit esp any any
 permit gre any any
 permit udp any any eq isakmp
 permit udp any any eq non500-isakmp
 permit udp any any eq bootpc
 deny   ip any any log
logging trap debugging
dialer-list 1 protocol ip permit
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
no vstack
line con 0
 no modem enable
line aux 0
 access-class ACL-CONSOLE-PERMIT in
line 2
 exec-timeout 60 0
 no activation-character
 no exec
 transport preferred none
 transport input all
 stopbits 1
line vty 0 4
 login local
 rotary 1
 transport input ssh
scheduler allocate 20000 1000
end
19 Replies 19
Which traffic do you want to allow ? Right now, your access list does not include any traffic originating from your inside (192.168.0.0.24).
I would like to allow outbound traffic towards the internet from 192.168.0.0/24.
would like to block incoming traffic from the internet towards the wan interface as per ACL outside_access_in.
add the line marked in bold to your access list:
--> permit ip 192.168.0.0 0.0.0.255 any
permit esp any any
permit gre any any
deny ip any any log
Thanks for that. I entered the permit rule as suggested above but it still doesn’t work. I can only reach out to 3.3.3.3 and 4.4.4.4 from source vlan1 192.168.0.0 but nothing else.
add the line in bold:
--> permit ip any 192.168.0.0 0.0.0.255
permit esp any any
permit gre any any
deny ip any any log
Sorry that still didn’t work...
permit ip 2.2.2.2 0.0.0.255 any
permit esp any any
permit gre any any
deny ip any any log
apply the access list outbound instead of inbound:
ip access-group outside_access_in out
If I apply outbound then the access to the internet from 192.168.0.0 works. However the ACL doesn’t work correctly. I can still ping my wan interface. So I don’t think it’s working correctly.
if you want to block pings, add the line in bold:
deny icmp any any echo-reply
permit esp any any
permit gre any any
deny ip any any log
Sorry that’s still not working. I do not think this ACL should on out the outbound of the interface as the ACL is not doing any inbound filtering if set on the outside.
Where is the ping originating, the Internet, or the inside of your network ?
The ping is originating from the internet.
Hello
May I ask what is it you are trying to allow it looks like anything from those two subnets and gre/ipsec traffic ?
Kind Regards
Paul
hi
i would like to allow 2.2.2.2 and 3.3.3.3 full access inbound from internet. Then also allow ipsec/gre/ike from any source but block everything else including ping to the wan interface itself from the internet.
