Cisco 897 ACL issue - block incoming traffic
I am facing an issue which I can't get my head around.  I would like to limit inbound traffic from the outside interface i.e. the WAN.  I have created an ACL and applied it to the WAN interface inbound.  However whenever I apply it, the ACL seems to works but all outbound traffic gets blocked too.
here is my config - any pointers would be much appreciated and I guess i'm missing something obvious!
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface Ethernet0
 no ip address
 shutdown
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
interface GigabitEthernet8
 ip address 1.1.1.1 255.255.255.248
 ip access-group outside_access_in in
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no cdp enable
interface Wlan-GigabitEthernet8
 no ip address
interface wlan-ap0
 no ip address
interface Vlan1
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 9.9.9.9
ip ssh port 2222 rotary 1
ip access-list extended ACL-CONSOLE-PERMIT
 permit ip 3.3.3.3 0.0.0.255 any
 permit ip 4.4.4.4 0.0.0.255 any
 deny   ip any any
ip access-list extended outside_access_in
 permit icmp any any time-exceeded
 permit icmp any any unreachable
 permit esp any any
 permit gre any any
 permit udp any any eq isakmp
 permit udp any any eq non500-isakmp
 permit udp any any eq bootpc
 deny   ip any any log
logging trap debugging
dialer-list 1 protocol ip permit
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
no vstack
line con 0
 no modem enable
line aux 0
 access-class ACL-CONSOLE-PERMIT in
line 2
 exec-timeout 60 0
 no activation-character
 no exec
 transport preferred none
 transport input all
 stopbits 1
line vty 0 4
 login local
 rotary 1
 transport input ssh
scheduler allocate 20000 1000
end
19 Replies 19
Hello
Try the follwoing, its a basic context based acl based on your requirements
ip inspect name CBAC tcp
ip inspect name CBAC udp
ip inspect name CBAC icmp
no ip access-list extended outside_access_in
deny icmp any any echo
permit ip host 2.2.2.2 any
permit ip host 3.3.3.3 any
permit esp any any
permit gre any any
no ip redirects
no ip unreachables
ip inspect CBAC out
Kind Regards
Paul
If I am understanding the original poster correctly they want to permit traffic from inside to the Internet (and inherently that also needs to permit the response traffic from the Internet) and want to permit traffic from a few Internet resources to access resources in the inside network. That is pretty much impossible if we are trying to do it with normal access lists. The key issue is what happens to responses coming from the Internet. We can sort of solve the issue for tcp traffic using permit tcp any any established, which will recognize tcp traffic that is a response to something initiated from inside. But we do not have a solution for udp traffic, or icmp traffic, or other sorts of traffic. The closest we can come is CBAC (as long as we are looking at using IOS devices). What we really want in this situation is something that does stateful inspection (like an ASA or other firewall type devices).
Rick
hi,
many thanks fo your suggestion. Unfortunately I tried this and this is the behaviour I am encountering.
- from the internet I am not able to ping the wan interface of the router - good
- from the internet and from 2.2.2.2 and 3.3.3.3 I am able to reach the router on all services - good
- From the inside lan network 192.168.0.0 I am unable to reach out to the internet - not intended
- from the inside lan network 192.168.0.0 I am only able to reach 2.2.2.2 and 3.3.3.3 via internet - not intended
it seems the outbound for some reason is getting blocked. Could it be because the ACL explicitly denies all so breakers the state full inbound traffic?
Hello
seems strange the cbac should work accordingly- Can you attach in a file the run config presently applied to that router?
Kind Regards
Paul
a Zone Based Firewall will work. The configuration is below (important parts marked in bold). Make sure to match everything exactly like below, as there are some intricacies (NAT and GRE/ESP require special attention):
class-map type inspect match-any OUT-T0-SELF-CM
match access-group name OUT-TO-SELF-ACL
class-map type inspect match-any GRE-ESP-CM
match access-group name GRE-ESP-ACL
class-map type inspect match-any SELF-TO-OUT-CM
match access-group name SELF-TO-OUT-ACL
class-map type inspect match-any INSIDE-TO-OUTSIDE-CM
match protocol isakmp
match protocol bootpc
match protocol icmp
match access-group name NON500-ISAKMP-ACL
class-map type inspect match-any OUTSIDE-TO-INSIDE-CM
match access-group name OUTSIDE-TO-INSIDE-ACL
policy-map type inspect OUTSIDE-TO-INSIDE-PM
class type inspect OUTSIDE-TO-INSIDE-CM
inspect
class type inspect GRE-ESP-CM
pass
class class-default
drop log
policy-map type inspect INSIDE-TO-OUTSIDE-PM
class type inspect INSIDE-TO-OUTSIDE-CM
inspect
pass
class class-default
drop log
policy-map type inspect SELF-TO-OUT-PM
class type inspect SELF-TO-OUT-CM
drop
class class-default
drop
policy-map type inspect OUT-TO-SELF-PM
class type inspect OUT-TO-SELF-CM
drop
class class-default
drop
zone security INSIDE
zone security OUTSIDE
zone-pair security INSIDE-TO-OUTSIDE-ZP source INSIDE destination OUTSIDE
service-policy type inspect INSIDE-TO-OUTSIDE-PM
zone-pair security OUTSIDE-TO-INSIDE-ZP source OUTSIDE destination INSIDE
service-policy type inspect OUTSIDE-TO-INSIDE-PM
zone-pair security OUT-TO-SELF-ZP source OUTSIDE destination self
service-policy type inspect OUT-TO-SELF-PM
zone-pair security SELF-TO-OUT-ZP source self destination OUTSIDE
service-policy type inspect SELF-TO-OUT-PM
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip nat enable
zone-member security OUTSIDE
duplex auto
speed auto
no cdp enable
no ip address
interface wlan-ap0
no ip address
interface Vlan1
ip nat enable
zone-member security INSIDE
no ip http server
ip nat source list 1 interface GigabitEthernet8 overload
deny ip any any
ip access-list extended GRE-ESP-ACL
permit gre any any
permit esp any any
ip access-list extended NON500-ISAKMP-ACL
ip access-list extended OUT-TO-SELF-ACL
deny ip any any
ip access-list extended OUTSIDE-TO-INSIDE-ACL
ip access-list extended SELF-TO-OUT-ACL
deny ip any any
control-plane
no vstack
line con 0
no modem enable
line aux 0
line 2
exec-timeout 60 0
no exec
transport input all
stopbits 1
line vty 0 4
login local
rotary 1
transport input ssh
end
