Cisco 9500 License
LINK1
Hello Community,
we have 2 cisco 9500-32QC and have stackwise-vitual. all of them have smart account license scheme. In the next output you can see that Switch-acitve licenses are in AUTHORIZED mode and Switch-stanby licenses are in EVALUATION mode:
Switch-active:
sCore#sh license sum
Smart Licensing is ENABLED
Registration:
Status: REGISTERED
Smart Account: TIEN PHAT TECHNOLOGY JOINT STOCK COMPANY
Virtual Account: DEFAULT
Export-Controlled Functionality: ALLOWED
Last Renewal Attempt: SUCCEEDED
Next Renewal Attempt: Apr 08 16:52:23 2021 VIE
License Authorization:
Status: AUTHORIZED
Last Communication Attempt: SUCCEEDED
Next Communication Attempt: Mar 01 11:48:03 2021 VIE
License Usage:
License Entitlement tag Count Status
C9500 32QC DNA Advan... (C9500-DNA-32QC-A) 1 AUTHORIZED
C9500 32QC NW Advantage (C9500-32QC-A) 1 AUTHORIZED
Switch-standby:
sCore-stby#sh license sum
Registration:
Status: UNREGISTERED
Export-Controlled Functionality: NOT ALLOWED
Status: EVAL MODE
Evaluation Period Remaining: 89 days, 23 hours, 10 minutes, 1 seconds
License Usage:
(C9500-DNA-32QC-A) 1 EVAL MODE
(C9500-32QC-A) 1 EVAL MODE
sCoreTPC-stby#sh lic all
Smart Licensing Status
Registration:
Status: EVAL MODE
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Callhome
License Usage
(C9500-DNA-32QC-A):
Description:
Count: 1
Version: 1.0
Status: EVAL MODE
Export status: NOT RESTRICTED
(C9500-32QC-A):
Description:
Count: 1
Version: 1.0
Status: EVAL MODE
Product Information
UDI: PID:C9500-32QC,SN:CAT2326L1MG
Agent Version
Smart Agent for Licensing: 4.5.12_rel/95
Component Versions: SA:(1_3_dev)1.0.15, SI:(dev22)1.2.1, CH:(rel5)1.0.3, PK:(dev18)1.0.3
Reservation Info
License reservation: DISABLED
Please kindly help us to investigate this issue.
Thanks!
9 Replies 9
balaji.bandi
is the device still reachable to cisco smart license server ?
  • Authorized State
    • This is the expected state when device is using an entitlement and is in Compliance (no negative balance),
    • The Virtual Account on CSSM had the correct type and number of licenses to authorize the consumption of the device’s licenses
    • At the end of 30 days, the device will send a new request to CSSM to renew the authorization.
    • Has a time span of 90 days after which (if not successfully renewed) is moved to Authorization Expired state.
here is troubleshoot guide :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9500-series-switches/214484-cisco-smart-licensing-troubleshooting.html
BB
LINK1
Dear BB,
Thanks for your recommendation.
Currently, When I access the device via the console port, the result is as above and Virtual accounts on CSSM have correct and sufficient number of device license permissions.
is this satellite License server on-prem ? or connecting to Cisco smart License Server.
is this device able to communicated to cisco License server ? yes or no ? please check.
you may have license, but device need to contact License server and validate.
BB
LINK1
Both switches are running redundancy with stackwise-virtual configuration so both switches share the same management ip and I also use this management ip to connect to the cisco license server.
+ switch-active: then get enough license
Switch-stanby: Can not get the license and there is a warning UNREGISTERED
So I am wondering if I should use comnand (license smart register idtoken <TOKEN> force) on the switch-standby device.
Hello @LINK1 ,
what about asking for a maintenance window and trying to make the standby active ( switchover ) to see if in this way it is able to register?
Hope to help
Giuseppe
Dear Giuseppe,
Thanks for your recommandation, It's worth a try. I have deregister and re-register licenses smart but ineffective.
Can you help me with the switch-over command to not affect the service during execution?
we run many SVL Cat 9500 - never observed this issue, both share same management IP that is correct.
we run this code - 16.12.01c
here running SVL output :
License Usage
C9500 48Y4C DNA Advantage (C9500-DNA-48Y4C-A):
Description: C9500 48Y4C DNA Advantage
Count: 2
Version: 1.0
Status: AUTHORIZED
C9500 Network Advantage (C9500 Network Advantage):
Description: C9500 Network Advantage
Count: 2
Version: 1.0
Status: AUTHORIZED
BB
LINK1
Dear BB,
I am using the version 16.09.03
in the next output. you can see SVL and License Usage:
License Usage
C9500 32QC DNA Advantage (C9500-DNA-32QC-A):
Description: C9500 32QC DNA Advantage
Count: 1
Version: 1.0
Status: AUTHORIZED
C9500 32QC NW Advantage (C9500-32QC-A):
Description: C9500 32QC NW Advantage
Count: 1
Version: 1.0
Status: AUTHORIZED
Stackwise Virtual Configuration:
Stackwise Virtual : Enabled
Domain Number : 2
Switch Stackwise Virtual Link Ports
1 1 HundredGigE1/0/45
HundredGigE1/0/46
HundredGigE1/0/47
2 1 HundredGigE2/0/45
HundredGigE2/0/46
HundredGigE2/0/47
can you help me in  any way?
balaji.bandi
I may be missed some information, what kind of issue you see here ? in terms of SVL ?
BB
