Cisco ASA 5505 VPN trouble
Kabashik
Hi everyone! Unknown error while configuring ASA's VPN. All commands are clear and 100% right, but when we start to test how it works we have error " The interesting traffic can not be encrypted, IKE (ISAKMP) needs to negotatiate IPSec SAs." A lot of different sources red, but don't know what to do with this. Screens and configs are below. Thanks!
if this is a Packet Tracer project, post your zipped project (.pkt) file.
6 Replies 6
Looking at the router configuration, there is no routing at all. Are you sure you sent the configuration of the correct router (the ISP router in your drawing) ?
Already downloaded .pkt, you can watch and write me
Kabashik
Already fixed, thanks everyone!
it seems to work just fine. The routing on the ISP router has been added, I can ping and get a valid SA:
Crypto map tag: TESTMAP, seq num: 10, local addr 192.168.1.2
permit icmp 192.168.3.0 255.255.255.0 192.168.4.0 255.255.255.0
local ident (addr/mask/prot/port): (192.168.3.0/255.255.255.0/1/0)
remote ident (addr/mask/prot/port): (192.168.4.0/255.255.255.0/1/0)
current_peer 192.168.2.2
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
#pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
#PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
#send errors 1, #recv errors 0
local crypto endpt.: 192.168.1.2/0, remote crypto endpt.:192.168.2.2/0
path mtu 1500, ip mtu, ipsec overhead 78, media mtu 1500
current outbound spi: 0x26E65432(652629042)
current inbound spi: 0x378A033A(652629042)
inbound esp sas:
spi: 0x378A033A(931791674)
transform: esp-aes esp-sha-hmac no compression
in use settings ={L2L, Tunnel, }
slot: 0, conn id: 2002, crypto map: TESTMAP
sa timing: remaining key lifetime (k/sec): (4525504/86396)
IV size: 16 bytes
replay detection support: N
Anti replay bitmap:
0x00000000 0x0000001F
outbound esp sas:
slot: 0, conn id: 2003, crypto map: TESTMAP
IV size: 16 bytes
Anti replay bitmap:
0x00000000 0x00000001
