Static Routing Won't Save
putra.research
I'm trying to make Static Routing in 3 routers. But 1 routers always won't save the static routing setting. Is there any solution?
2 Accepted Solutions
Hello
You had incorrect ip address assignment on your router interfaces and incorrect static routes.
Suggest as you have multiple egress paths on the rtrs not to use static routing as this would be to much of an administrative burden to manage and instead use an igp such as rip/eigrp/ospf.
Kind Regards
Paul
 the static route is not saved because the next hop is not on the same subnet. You need to change the IP addressing on RouterA (and RouterB) as below (revised file attached):
RouterA#sh run
Building configuration...
Current configuration : 661 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname RouterA
ip cef
no ipv6 cef
interface GigabitEthernet7/0
ip address 192.168.1.1 255.255.255.252
interface GigabitEthernet8/0
ip address 192.168.1.6 255.255.255.252
interface FastEthernet9/0
ip address 172.17.1.1 255.255.255.0
duplex auto
speed auto
ip classless
ip route 10.20.30.0 255.255.255.0 192.168.1.2
ip route 192.168.100.0 255.255.255.0 192.168.1.14
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
RouterB#sh run
Current configuration : 674 bytes
version 12.2
hostname RouterB
ip cef
no ipv6 cef
ip address 192.168.1.9 255.255.255.252
ip address 192.168.1.2 255.255.255.252
ip address 10.20.30.1 255.255.255.0
duplex auto
speed auto
ip classless
ip route 172.17.1.0 255.255.255.0 192.168.1.1
ip route 192.168.100.0 255.255.255.0 192.168.1.10
line con 0
line aux 0
line vty 0 4
login
end
RouterC#sh run
Current configuration : 658 bytes
version 12.2
hostname RouterC
ip cef
no ipv6 cef
ip address 192.168.1.5 255.255.255.252
ip address 192.168.1.10 255.255.255.252
ip address 40.50.60.1 255.255.255.0
duplex auto
speed auto
ip classless
ip route 172.17.1.0 255.255.255.0 192.168.1.6
ip route 10.20.30.0 255.255.255.0 192.168.1.9
line con 0
line aux 0
line vty 0 4
login
end
Hello
Kind Regards
Paul
Thank you so much for your suggestion. Aprreciate it
RouterA#sh run
version 12.2
hostname RouterA
ip cef
no ipv6 cef
duplex auto
speed auto
ip classless
line con 0
line aux 0
line vty 0 4
login
end
RouterB#sh run
version 12.2
hostname RouterB
ip cef
no ipv6 cef
duplex auto
speed auto
ip classless
line con 0
line aux 0
line vty 0 4
login
end
RouterC#sh run
version 12.2
hostname RouterC
ip cef
no ipv6 cef
duplex auto
speed auto
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Thankyou so much, it's work!
