Cisco ASR 1001 CBWFQ Not supported on subinterfaces and efps
gomez.juan
I have problems to configure CBWFQ on a ethernet sub-interface on a Cisco Router ASR 1001. Then I applied the policy in the physical interface but it should be is in the sub-interface.  How can I configure CBWFQ on sub-interface in ASR 1001. (version 3.02).
Error Messages:
CBWFQ: Not supported on subinterfaces and efps
This the final output:
interface GigabitEthernet0/0/0
description Conexion WAN
bandwidth 153600
no ip address
load-interval 30
no negotiation auto
service-policy output voice-policy-VoIP-CriticalData
hold-queue 4096 in
interface GigabitEthernet0/0/0.100
description Conexion Wan
bandwidth 153600
encapsulation dot1Q 100
ip address 10.10.0.1 255.255.255.252
Nandan Mathure
@gomez.juan
You can create a PARENT policy map as follows and call the CHILD policy (
voice-policy-VoIP-CriticalData) with in:
policy-map PARENTvoice-policy-VoIP-CriticalData
class class-default
service-policy voice-policy-VoIP-CriticalData
shape average percent 100
service-policy out PARENTvoice-policy-VoIP-CriticalData
Note: This is just a trick where in we dont direcly apply a CBFQ on subinterface but into a parent policy.
Also here shaping is necessary for PARENT polciy to work. Shaping is kept @ 100% so as good as no change.
Plz let me know if this worked.
Nandan Mathure
@gomez.juan
class class-default
Thank you very much, this solved the problem of sub-interface CBWFQ
