Cisco ASR1002 - no "monitor capture" command
Lee Kendrick
I am trying to run a capture on one of my ASR 1002 routers, however the EPC monitor capture command is not available.
Please can someone provide some insight on how i can either resolve this or an alternative method.
I am not on site to make any physical changes:
RTWAN2#monitor ?
  call         Monitor call
  elog         Event-logging control commands
  event-trace  Control event tracing
  platform     Monitor platform information
  processes    Monitor processes
RTWAN2#
Many thanks
Lee
Vignesh Rajendran Praveen
Hi Lee,
The EPC feature is only available from 15.3(1)S IOS-XE version onwards.
http://www.cisco.com/en/US/partner/docs/ios-xml/ios/epc/configuration/xe-3s/asr1000/nm-packet-capture-xe.html
Kindly confirm the IOS-XE version that your using on the device. If possible share the show version output from the device.
****Plz do rate this post without fail if you found it to be helpful*********
Thanks & Regards,
Vignesh R P
