Cisco C1111-8P Double NAT with NETGEAR V7610
woohs1216
Hi all,
I am trying to configure Cisco C1111 router, getting the WAN connection from an existing NETGEAR V7610, which will work as a VDSL modem.
WAN <-> NETGEAR (192.168.15.1) <-> (192.168.15.53) CISCO (192.168.1.1) <-> (192.168.1.x) PCs
I have configured NAT, from the Cisco end, but I am seeing very strange behaviour from the PCs connected to it.
1. The PCs say the internet is connected.
2. Web browsing works rarely. Sometimes it loads a page from the internet, but mostly (95%) it doesn't. I think it works well for a minute when I reboot the Cisco router.
3. Pinging is very stable. I do not think it's a DNS issue as it Pings to various internet address without any issues.
I am not understanding why the router is behaving like this.
CONFIG
ip name-server 192.168.15.1 8.8.4.4 8.8.8.8
ip dhcp excluded-address 192.168.1.255 255.255.255.255
ip dhcp excluded-address 192.168.1.0 192.168.1.49
ip dhcp pool WEBUIpool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1 8.8.8.8 8.8.4.4
lease infinite
vlan internal allocation policy ascending
track 1 ip sla 1 reachability
interface GigabitEthernet0/0/0
description Telstra_Gateway
ip address dhcp
ip nat outside
ip ospf bfd
media-type rj45
negotiation auto
spanning-tree portfast disable
interface GigabitEthernet0/0/1
no ip address
ip nat outside
shutdown
media-type rj45
negotiation auto
interface GigabitEthernet0/1/0
switchport mode access
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface Vlan1
ip nat inside
no autostate
ip http server
ip http authentication local
ip http secure-server
ip forward-protocol nd
ip dns server
ip nat inside source list 11 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 track 1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 192.168.15.1
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0/0
ip sla schedule 1 life forever start-time now
ip access-list standard 11
10 remark define internal networks
10 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
route-map track-primary-if permit 1
match ip address 197
set interface GigabitEthernet0/0/0
route-map track-secondary-if permit 1
set interface GigabitEthernet0/0/1
Can someone help me with the configuration?
balaji.bandi
i suggest below steps :
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 track 1
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 192.168.15.1
ip route 0.0.0.0 0.0.0.0 192.168.15.1
change the DNS order :
dns-server 8.8.8.8 8.8.4.4
when the PC slow internet from router are you able to ping google.com ?
post show interface gig 0/0/0 (see any Inerface errors)
when the you have issue, show nat tranlation. and any logs (show logging ?)
BB
