Cisco CME SIP Trunk Call Fails with Cause Value 3 and SIP 404 – Help
CaCa126
I currently have an internal VLAN 1011, and all internal IP phones can communicate with each other without any issues. However, no matter what I try, I just can’t make outbound calls to external/public numbers, nor can I get the configuration to enable external calling to work. I would really appreciate any help or guidance from the experts here.
Here goes my current config and debug:
Thank you so much for helping me with this!!!
Kind Regards,
Caca
6 Replies 6
You should not have a session target on your inbound dial peer, and it should absolutely not be pointed to an IP in your CME router and you should add bind statement to your dial peers so that it uses the appropriate interface to communicate.
Response Signature
Thank you very much for your reply and help. I have now modified my dial-peer configuration as per your instructions. However, calls to the public number 966115189XXX still do not go through. Below is my latest configuration and debug information. I kindly ask for your further assistance. Thank you so much!
dial-peer voice 1000 voip
description *** Outbound SIP Trunk to Mobily ***
destination-pattern 96611518....
b2bua
session protocol sipv2
session target ipv4:10.138.120.249
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/0/1
voice-class sip bind media source-interface GigabitEthernet0/0/1
dtmf-relay rtp-nte
no vad
dial-peer voice 2000 voip
description **Inbound from Mobily SIP Trunk**
b2bua
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
Here is my debug ccsip messages log.
SIP Call messages tracing is enabled
CME#undebug all
All possible debugging has been turned off
CME#show logg
Jun 9 05:57:06.514: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:966115189687@172.16.50.1;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.16.50.19:5060;branch=z9hG4bK2fff489a
From: "Secretary" <sip:1044@172.16.50.1>;tag=2c5741135f0f001340aa48ed-50d0e5f8
To: <sip:966115189687@172.16.50.1>
Call-ID: 2c574113-5f0f000e-6c9ed44f-763adc98@172.16.50.19
Max-Forwards: 70
Session-ID: 57cee4d800105000a0002c5741135f0f;remote=00000000000000000000000000000000
Date: Mon, 09 Jun 2025 05:57:05 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP7821/12.7.1
Contact: <sip:5479A-10C7@172.16.50.19:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP2C5741135F0F"
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Secretary" <sip:1044@172.16.50.1>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Recv-Info: conference
Recv-Info: x-cisco-conference
Content-Length: 349
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 26046 0 IN IP4 172.16.50.19
s=SIP Call
b=AS:4064
t=0 0
m=audio 17904 RTP/AVP 0 8 116 18 101
c=IN IP4 172.16.50.19
b=TIAS:64000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
Jun 9 05:57:06.518: //29187/6874391F8F15/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 09 Jun 2025 05:57:06 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-16.9.5
Session-ID: 00000000000000000000000000000000;remote=57cee4d800105000a0002c5741135f0f
Content-Length: 0
Jun 9 05:57:06.522: //29188/6874391F8F15/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:966115189687@10.138.120.249:5060 SIP/2.0
Via: SIP/2.0/UDP 10.180.17.114:5060;branch=z9hG4bK7A82D1
Remote-Party-ID: "Secretary" <sip:1044@10.180.17.114>;party=calling;screen=yes;privacy=off
From: "Secretary" <sip:1044@10.138.120.249>;tag=40F9FB9-1B58
To: <sip:966115189687@10.138.120.249>
Call-ID: 6875235B-442D11F0-8F1BB6FD-93511C0@10.180.17.114
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1752447263-1143804400-2400564989-0154472896
User-Agent: Cisco-SIPGateway/IOS-16.9.5
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1749448626
Contact: <sip:1044@10.180.17.114:5060>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 4266 7896 IN IP4 10.180.17.114
s=SIP Call
c=IN IP4 10.180.17.114
t=0 0
m=audio 8114 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
Jun 9 05:57:06.784: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.180.17.114:5060 SIP/2.0
Via: SIP/2.0/UDP 10.138.120.249:5060;branch=z9hG4bKg9otfyfgro5g9u5owu9qroqgx;Role=3;Hpt=8f08_16;TRC=ffffffff-ffffffff;pth=0;X-HwDim=4
Call-ID: y7xfu55rr9ouiwqq9ixu7vz9ofoutgg5@249.120.138.10
To: <sip:10.180.17.114>
CSeq: 1 OPTIONS
Contact: <sip:10.138.120.249:36616;transport=udp;Hpt=8f08_16>;expires=65535
Max-Forwards: 70
Content-Length: 0
Jun 9 05:57:06.786: //29189/689D44488F1C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.180.17.114>;tag=40FA0C0-1375
CSeq: 1 OPTIONS
Content-Length: 377
v=0
o=CiscoSystemsSIP-GW-UserAgent 3059 2582 IN IP4 10.180.17.114
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Jun 9 05:57:07.022: //29188/6874391F8F15/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 09 Jun 2025 05:57:07 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1749448627
Expires: 180
Max-Forwards: 69
Content-Length: 249
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Jun 9 05:57:07.282: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jun 9 05:57:07.283: //29189/689D44488F1C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 377
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jun 9 05:57:08.021: //29188/6874391F8F15/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 09 Jun 2025 05:57:08 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1749448628
Expires: 180
Max-Forwards: 69
Content-Length: 249
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Jun 9 05:57:08.282: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jun 9 05:57:08.283: //29189/689D44488F1C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 377
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jun 9 05:57:10.022: //29188/6874391F8F15/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 09 Jun 2025 05:57:10 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1749448630
Expires: 180
Max-Forwards: 69
Content-Length: 249
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Jun 9 05:57:10.234: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
^@-^^@-^^@-^^@-^.50.1 SIP/2.0
Via: SIP/2.0/UDP 172.16.50.151:5060;branch=z9hG4bK0460783d
From: "AUTO-REG" <sip:AUTO-REG@172.16.50.151>;tag=2c574113575c3dc8479c50b0-4d868e07
To: <sip:172.16.50.1>
Call-ID: 2c574113-575c3088-0355af35-46972a6f@172.16.50.151
Session-ID: 181f013f00105000a0002c574113575c;remote=00000000000000000000000000000000
Date: Mon, 09 Jun 2025 05:56:45 GMT
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Contact: <sip:AUTO-REG@172.16.50.151:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP2C574113575C"
Require: norefersub
Referred-By: "AUTO-REG" <sip:AUTO-REG@172.16.50.151>
Refer-To: cid:21694b8b@172.16.50.151
Content-Id: <21694b8b@172.16.50.151>
Content-Length: 1683
Content-Type: application/x-cisco-alarm+xml
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-alarm>
<Alarm Name="LastOutOfServiceInformation">
<ParameterList>
<String name="DeviceName">SEP2C574113575C</String>
<String name="DeviceIPv4Address">172.16.50.151/24</String>
<String name="IPv4DefaultGateway">172.16.50.1</String>
<String name="DeviceIPv6Address"></String>
<String name="IPv6DefaultGateway"></String>
<String name="ModelNumber">CP-7821</String>
<String name="NeighborIPv4Address">172.16.0.11</String>
<String name="NeighborIPv6Address"></String>
<String name="NeighborDeviceID">C7AramcoATSW</String>
<String name="NeighborPortID">GigabitEthernet1/0/26</String>
<Enum name="DHCPv4Status">1</Enum>
<Enum name="DHCPv6Status">3</Enum>
<Enum name="TFTPCfgStatus">1</Enum>
<Enum name="DNSStatusUnifiedCM1">0</Enum>
<Enum name="DNSStatusUnifiedCM2">0</Enum>
<Enum name="DNSStatusUnifiedCM3">0</Enum>
<Enum name="DNSv6StatusUnifiedCM1">0</Enum>
<Enum name="DNSv6StatusUnifiedCM2">0</Enum>
<Enum name="DNSv6StatusUnifiedCM3">0</Enum>
<String name="VoiceVLAN"></String>
<String name="UnifiedCMIPAddress">172.16.50.1</String>
<String name="LocalPort">0</String>
<String name="TimeStamp">1749448605317</String>
<Enum name="ReasonForOutOfService">24</Enum>
<String name="LastProtocolEventSent">Sent:REGISTER sip:172.16.50.1 SIP/2.0 Cseq:3489 REGISTER CallId:2c574113-575c0995-4e23ac7f-6dcba330@172.16.50.151 </String>
<String name="LastProtocolEventReceived">Rcvd:SIP/2.0 404 Not Cseq:1584 REGISTER CallId:2c574113-575c0225-2da77ed1-4f7b9ae3@172.16.50.83 </String>
<String name="ReasonForOutOfServiceText">LastTimePhoneRegRej</String>
<String name="ActiveInterface">Wired</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Jun 9 05:57:10.284: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jun 9 05:57:10.285: //29189/689D44488F1C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 377
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jun 9 05:57:12.401: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.16.50.133:5060;branch=z9hG4bK6b91b2ac
From: "AUTO-REG" <sip:AUTO-REG@172.16.50.133>;tag=2c5741136d173e0c4909ffc9-662c26d1
Call-ID: 2c574113-6d1730c4-306b3b5b-7685516d@172.16.50.133
Session-ID: dee9716b00105000a0002c5741136d17;remote=00000000000000000000000000000000
Date: Mon, 09 Jun 2025 05:56:55 GMT
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Contact: <sip:AUTO-REG@172.16.50.133:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP2C5741136D17"
Require: norefersub
Referred-By: "AUTO-REG" <sip:AUTO-REG@172.16.50.133>
Refer-To: cid:02a5e2f0@172.16.50.133
Content-Id: <02a5e2f0@172.16.50.133>
Content-Type: application/.n.o>co-alara^B^C.l
<x-cisco-alarm>
<ParameterList>
<String name="DeviceName">SEP2C5741136D17</String>
<String name="DeviceIPv4Address">172.16.50.133/24</String>
<String name="NeighborPortID">GigabitEthernet1/0/33</String>
<String name="TimeStamp">1749448615413</String>
<String name="LastProtocolEventSent">Sent:REGISTER sip:172.16.50.1 SIP/2.0 Cseq:3496 REGISTER CallId:2c574113-6d17099d-3df954a5-00938f2c@172.16.50.133 </String>
<String name="LastProtocolEventReceived">Rcvd:SIP/2.0 404 Not Cseq:1592 REGISTER CallId:2c574113-6d17022d-6b31318e-41550505@172.16.50.64 </String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Jun 9 05:57:14.023: //29187/6874391F8F15/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 408 Request Timeout
To: <sip:966115189687@172.16.50.1>;tag=40FBD06-22E2
CSeq: 101 INVITE
Reason: Q.850;cause=102
Content-Length: 0
Jun 9 05:57:14.050: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:966115189687@172.16.50.1;user=phone SIP/2.0
Max-Forwards: 70
Date: Mon, 09 Jun 2025 05:57:13 GMT
CSeq: 101 ACK
Content-Length: 0
Jun 9 05:57:14.792: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.138.120.249:5060;branch=z9hG4bKutwtu59wgoxgfgqiqz5voy9wv;Role=3;Hpt=8f08_16;TRC=ffffffff-ffffffff;pth=0;X-HwDim=4
Call-ID: v9zoioigxfyvg555g97try9ziyzv7qvw@249.120.138.10
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jun 9 05:57:14.794: //29190/6D6357EE8F1D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.180.17.114>;tag=40FC009-727
Date: Mon, 09 Jun 2025 05:57:14 GMT
CSeq: 1 OPTIONS
Content-Length: 377
v=0
o=CiscoSystemsSIP-GW-UserAgent 1427 2195 IN IP4 10.180.17.114
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jun 9 05:57:15.287: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jun 9 05:57:15.288: //29190/6D6357EE8F1D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 09 Jun 2025 05:57:15 GMT
CSeq: 1 OPTIONS
Content-Length: 377
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jun 9 05:57:16.075: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.16.50.127:5060;branch=z9hG4bK6db1d957
From: "AUTO-REG" <sip:AUTO-REG@172.16.50.127>;tag=d4adbdf4e8903de42e623acb-153253fb
Call-ID: d4adbdf4-e89030a7-4f015950-3babb0d3@172.16.50.127
Session-ID: 11b7053500105000a000d4adbdf4e890;remote=00000000000000000000000000000000
Date: Mon, 09 Jun 2025 05:56:53 GMT
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Contact: <sip:AUTO-REG@172.16.50.127:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEPD4ADBDF4E890"
Require: norefersub
Referred-By: "AUTO-REG" <sip:AUTO-REG@172.16.50.127>
Refer-To: cid:759d8e41@172.16.50.127
Content-Id: <759d8e41@172.16.50.127>
<x-cisco-alarm>
<ParameterList>
<String name="DeviceName">SEPD4ADBDF4E890</String>
<String name="DeviceIPv4Address">172.16.50.127/24</String>
<String name="NeighborPortID">GigabitEthernet1/0/16</String>
<String name="TimeStamp">1749448613323</String>
<String name="LastProtocolEventSent">Sent:REGISTER sip:172.16.50.1 SIP/2.0 Cseq:3485 REGISTER CallId:d4adbdf4-e8900991-3cc89848-17ed1b3c@172.16.50.127 </String>
<String name="LastProtocolEventReceived">Rcvd:SIP/2.0 404 Not Cseq:1591 REGISTER CallId:d4adbdf4-e890022b-56f1aa61-4eab91d7@172.16.50.59 </String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Jun 9 05:57:16.289: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jun 9 05:57:16.290: //29190/6D6357EE8F1D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 09 Jun 2025 05:57:16 GMT
CSeq: 1 OPTIONS
Content-Length: 377
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
CME#
I look forward to your reply once again. Thank you again for your help.
By the looks of your debug output you’re sending multiple invites to your service provider, but they aren’t responding to them and eventually the call fails with timer expiry. Looking at your configuration I see that you haven’t enabled the Cube functionality in your router and you have b2bua set on your dial peers. That’s quite unusual to have on SIP trunk dial peers. What type of trunk do you have with your service provider, registration based or just a plain trunk with no registration?
One comment not related to your problem, please do not post debug output directly inline in your response. That makes the post very difficult to read. Also please collect the output from your debugs into one file instead of having them separated into multiple files.
This document should help you with how to setup your router as an SBC Cisco Unified Border Element Configuration Guide - Cisco IOS XE 17.6 Onwards and this document should help you better understand how call routing operates in IOS Explain Cisco IOS and IOS XE Call Routing
Response Signature
Hello, thank you very much for your reply and suggestions. I’m currently using a Mobily SIP Trunk in “No Registration” mode. At the moment, public outbound calls are still showing error codes 102 and 408 in the debug ccsip calls output. If you have any suggestions, please feel free to contact me at any time.
Suggest that you start by removing the b2bua command from the dial peers and turning on the Cube functionality in global voice configuration by the mode border-element command. I would also recommend that you remove the registration configuration for the service provider IP under sip-ua section. When done please collect the output from these debugs in text file, debug ccsip message and debug voip ccapi inout that you post in your answer.
Response Signature
To add to my previous response. Both cause code 102 and 408 are related to timeout in response.
Response Signature
