Cisco DS3 Card
abbas.ali
Does Cisco 3800 routers support DS3 or T3 Technology. If not, What Cisco Router will support DS3 or T3 Card?
paolo bevilacqua
Yes it does, NM-1T3/E3. The next bigger router is the 7200.
Hope this helps, if so please rate post!
3800 Series routers sure does support DS3 cards. Look under table 3 in the link below.
http://cisco.com/en/US/products/ps5855/products_quick_start09186a00802d11be.html
Use Cisco Feature Navigator tool on CCO and select the 'search by platform' option and to configure the hardware. Here's the link..
Sundar
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Eventhough 3824 supports T3, but what does it refer to in a model comparison chart that 3824 only supports 1/2 T3 (Services at Line Rate) while 3845 supports T3 (Services at line rate.
It means full and half-duplex connectivity at DS3/E3 rate (44.736 MHz/ 34.368 MHz)
Check this out http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a008010fba2.html
