Cisco Firepower 1010 - Multicast Routing
Hi all,
hope to find everyone well.
I have a Cisco Firepower 1010 and I was asked if it could execute Multicast Routing, but after checking the manual it seems this isn't supported in this model. But the manual also states that Dynamic Routing is not supported and I can see BGP and OSPF in the configuration menu of the device. Please can anyone in fact confirm if multicast is not supported?
What other model of firepower can I use to execute multicast routing?
Thank you all before hand
i normally do not use FDM, FMC it is possible.
Technically you can do using FDM too as below guide :
EDIT :
Multicast routing
FlexConfig
Configure multicast routing using FlexConfig objects from the Device > Advanced Configuration page.
BB
balaji.bandi
what version FTD running, how are you managing this device ? using FMC or FDM ?
here is config guide and limitation :
https://www.cisco.com/c/en/us/td/docs/security/firepower/640/configuration/guide/fpmc-config-guide-v64/multicast_routing_for_firepower_threat_defense.html
BB
Hi @balaji.bandi
thank you for the reply!
So, this device is being managed via the FDM and not the FMC and we are not thinking of putting it in the FMC. Only trough the FDM is Multicast feasible?
Thank you
EDIT :
Multicast routing
FlexConfig
BB
Thank you Balaji!
I was just checking the link that you posted and I can see multicast configuration for Precision Time Protocol (ISA 3000 only). But can't see anything else related with multicast
Thank you
