Cisco GETVPN over MPLS Issue
mediaos718
I have 2 sites connected over MPLS.
R1 is the CE router (Network: 10.0.0.0/8)
R2 is the PE router in SITE-1 (Using network: 192.168.0.0/16 and 172.16.0.0/16
R7 is PE the router in SITE-2 (Using network: 192.168.0.0/16 and 172.16.0.0/16)
R9 is the CE router in SITE-2 (Using network: 10.0.0.0/8)
Key Server and Certificate Server are using network 172.16.0.0/16
I enabled GETVPN on R7 only.
I configured an access-list on the Key Server (KS) to:
1) Not to encrypt BGP between the PEs (R2 and R7)
2) Not to encrypt OSPF traffic between the PEs (R2 and R7)
3) Not to Encrypt LDP traffic between the PEs (R2 and R7)
Since I enabled GETVON on only SITE-2, I should not be able to ping between the CE routers.
- The problem is that I am able to ping between the CE's.
- The only time that I am unable to ping between the CE is when I modify the ACL on the Key server encrypt (BGP or OSPF or LDP).
- Observation: GETVPN is encrypting the BGP, OSPF, and the LDP (on the 192.168.0.0/16 and 172.16.0.0/16) but not traffic on the (10.0.0.0/8)
Please let me know I am doing wrong here. I will send config and show output upon request.
R7#sh crypto gdoi
GROUP INFORMATION
    Group Name               : LEVEL3-VPLS-GROUP
    Group Identity           : 1234
    Crypto Path              : ipv4
    Key Management Path      : ipv4
    Rekeys received          : 19
    IPSec SA Direction       : Both
     Group Server list       : 172.16.50.12
    Group member             : 192.168.200.7    vrf: None
       Version               : 1.0.4
       Registration status   : Registered
       Registered with       : 172.16.50.12
       Re-registers in       : 140 sec
       Succeeded registration: 1
       Attempted registration: 1
       Last rekey from       : 172.16.50.12
       Last rekey seq num    : 0
       Unicast rekey received: 19
       Rekey ACKs sent       : 19
       Rekey Rcvd(hh:mm:ss)  : 00:00:46
       allowable rekey cipher: any
       allowable rekey hash  : any
       allowable transformtag: any ESP
    Rekeys cumulative
       Total received        : 19
       After latest register : 19
       Rekey Acks sents      : 19
ACL Downloaded From KS 172.16.50.12:
   access-list   deny ip 192.168.0.0 0.0.255.255 host 224.0.0.2
   access-list   deny ip 192.168.0.0 0.0.255.255 host 224.0.0.3
   access-list   deny ip 192.168.0.0 0.0.255.255 host 224.0.0.4
   access-list   deny ip 192.168.0.0 0.0.255.255 host 224.0.0.5
   access-list   deny ip 192.168.0.0 0.0.255.255 host 224.0.0.6
   access-list   deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
   access-list   deny ip 172.16.0.0 0.0.255.255 172.16.0.0 0.0.255.255
   access-list   permit ip any any
KEK POLICY:
    Rekey Transport Type     : Unicast
    Lifetime (secs)          : 252
    Encrypt Algorithm        : 3DES
    Key Size                 : 192
    Sig Hash Algorithm       : HMAC_AUTH_SHA
    Sig Key Length (bits)    : 512
TEK POLICY for the current KS-Policy ACEs Downloaded:
  Ethernet1/2:
    IPsec SA:
        spi: 0xA36FCACE(2742012622)
        transform: esp-3des esp-md5-hmac
        sa timing:remaining key lifetime (sec): (780)
        Anti-Replay(Time Based) : 5 sec interval
I could not replicate your exact setup, but for the sake of simplicity, I created a network of 4 routers, with R3 being the Key Server, and R1 and R4 being the GMs.
The access list configured on the KS works as designed, check if that (working) config helps you. (Notice that I disabled the replay window on the KS, for some reason, it did not work in GNS3).
All routers run EIGRP, BGP, and OSPF. I have included a picture of the setup.
R1
Current configuration : 1954 bytes
! Last configuration change at 01:06:51 UTC Mon Feb 13 2017
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
lifetime 300
crypto isakmp key tempkey1 address 10.0.0.1
crypto gdoi group GDOI-GROUP1
identity number 12345
server address ipv4 3.3.3.3
crypto map gdoimap 1 gdoi
set group GDOI-GROUP1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet1/0
negotiation auto
crypto map gdoimap
router eigrp 1
network 1.1.1.1 0.0.0.0
network 192.168.1.0
router ospf 1
network 1.1.1.1 0.0.0.0 area 0
network 192.168.1.0 0.0.0.255 area 0
router bgp 1
bgp log-neighbor-changes
network 1.1.1.1 mask 255.255.255.255
network 192.168.1.0
neighbor 192.168.1.2 remote-as 2
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2
Current configuration : 1915 bytes
! Last configuration change at 22:37:30 UTC Sun Feb 12 2017
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 192.168.1.2 255.255.255.0
negotiation auto
interface GigabitEthernet2/0
ip address 192.168.2.1 255.255.255.0
negotiation auto
interface GigabitEthernet3/0
ip address 192.168.3.1 255.255.255.0
negotiation auto
router eigrp 1
network 2.2.2.2 0.0.0.0
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
router ospf 1
network 2.2.2.2 0.0.0.0 area 0
network 192.168.2.0 0.0.0.255 area 0
network 192.168.3.0 0.0.0.255 area 0
router bgp 2
network 2.2.2.2 mask 255.255.255.255
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
neighbor 192.168.1.1 remote-as 1
neighbor 192.168.2.2 remote-as 4
neighbor 192.168.3.2 remote-as 3
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3
Current configuration : 2480 bytes
! Last configuration change at 02:08:09 UTC Mon Feb 13 2017
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr aes
group 2
crypto isakmp key tempkey1 address 0.0.0.0
crypto ipsec transform-set aes128 esp-aes esp-sha-hmac
mode tunnel
crypto ipsec profile profile1
set transform-set aes128
server local
rekey algorithm aes 128
rekey retransmit 10 number 3
rekey authentication mypubkey rsa REKEYRSA
rekey transport unicast
sa ipsec 1
profile profile1
match address ipv4 getvpn-acl
no replay
interface Loopback0
ip address 3.3.3.3 255.255.255.255
ip address 192.168.3.2 255.255.255.0
negotiation auto
router eigrp 1
network 3.3.3.3 0.0.0.0
network 192.168.3.0
router ospf 1
network 3.3.3.3 0.0.0.0 area 0
router bgp 3
network 3.3.3.3 mask 255.255.255.255
network 192.168.3.0
neighbor 192.168.3.1 remote-as 2
no ip http server
ip access-list extended getvpn-acl
deny udp any any eq 646
deny tcp any any eq 646
deny tcp any any eq bgp
deny tcp any eq bgp any
deny ospf any any
deny udp any eq 848 any eq 848
deny tcp any any eq 22
deny tcp any eq 22 any
permit ip any any
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R4
! Last configuration change at 01:11:48 UTC Mon Feb 13 2017
version 15.2
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr aes
group 2
lifetime 300
crypto isakmp key tempkey1 address 3.3.3.3
interface Loopback0
ip address 4.4.4.4 255.255.255.255
ip address 192.168.2.2 255.255.255.0
negotiation auto
crypto map gdoimap
router eigrp 1
network 4.4.4.4 0.0.0.0
network 192.168.2.0
router ospf 1
network 4.4.4.4 0.0.0.0 area 0
router bgp 4
network 4.4.4.4 mask 255.255.255.255
network 192.168.2.0
neighbor 192.168.2.1 remote-as 2
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
20 Replies 20
post the full configs of the routers.
Georg (There is a third site - but for the sake of troubleshooting I include 2 sites)
R1
interface Loopback0
ip address 10.1.255.1 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex full
interface Ethernet1/0
no ip address
duplex full
interface Ethernet1/0.1000
encapsulation dot1Q 1000
ip address 10.0.0.1 255.255.255.0
interface Ethernet1/1
no ip address
duplex full
interface Ethernet1/1.900
encapsulation dot1Q 900
ip address 10.0.1.1 255.255.255.0
interface Ethernet1/2
no ip address
shutdown
duplex full
interface Ethernet1/3
no ip address
shutdown
duplex full
router eigrp 1
network 10.0.0.0
router bgp 1000
network 10.0.0.0 mask 255.255.255.0
network 10.0.1.0 mask 255.255.255.0
network 10.1.255.1 mask 255.255.255.255
neighbor 10.0.0.2 remote-as 100
neighbor 10.0.1.3 remote-as 200
R2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip vrf DC-1
rd 100:1
route-target export 100:1
route-target import 100:1
ip vrf SITE-1
rd 101:1
route-target export 101:1
route-target import 101:1
route-target import 102:1
ip vrf SITE-2
rd 102:1
route-target export 102:1
ip cef
no ipv6 cef
crypto pki trustpoint DPCert
enrollment url http://192.168.50.10:80
revocation-check none
ip ssh version 1
crypto isakmp policy 50
encr 3des
hash md5
group 2
crypto gdoi group LEVEL3-VPLS-GROUP
server address ipv4 172.16.50.12
crypto map LEVEL3-VPLS-MAP local-address Loopback0
crypto map LEVEL3-VPLS-MAP 10 gdoi
set group LEVEL3-VPLS-GROUP
interface Loopback0
ip address 192.168.200.2 255.255.255.255
no ip address
shutdown
duplex full
no ip address
duplex full
ip vrf forwarding SITE-1
ip address 10.0.0.2 255.255.255.0
ip address 192.168.100.2 255.255.255.0
shutdown
duplex full
mpls ip
mpls bgp forwarding
duplex full
mpls ip
mpls bgp forwarding
interface Ethernet1/2.100
shutdown
no ip address
shutdown
duplex full
router eigrp 1
network 10.0.0.0
router ospf 1
network 192.168.100.0 0.0.0.255 area 0
network 192.168.200.2 0.0.0.0 area 0
router bgp 100
neighbor 192.168.200.7 remote-as 100
neighbor 192.168.200.7 update-source Loopback0
address-family vpnv4
  neighbor 192.168.200.7 activate
  neighbor 192.168.200.7 send-community both
exit-address-family
address-family ipv4 vrf SITE-1
  neighbor 10.0.0.1 remote-as 1000
  neighbor 10.0.0.1 activate
exit-address-family
R7
hostname R7
boot-start-marker
boot-end-marker
no aaa new-model
ip vrf DC-1
rd 100:1
ip vrf SITE-1
rd 101:1
ip vrf SITE-2
rd 102:1
ip cef
no ipv6 cef
ip ssh version 1
encr 3des
hash md5
group 2
interface Loopback0
ip address 192.168.200.7 255.255.255.255
interface Loopback1000
ip vrf forwarding DC-1
ip address 10.100.100.100 255.255.255.255
ip address 192.168.3.7 255.255.255.0
duplex half
no ip address
duplex full
interface Ethernet1/0.900
ip address 10.0.5.7 255.255.255.0
ip address 192.168.102.7 255.255.255.0
duplex full
mpls ip
ip address 192.168.1.7 255.255.255.0
duplex full
mpls ip
mpls bgp forwarding
shutdown
no ip address
shutdown
duplex full
interface Ethernet2/0
ip address 192.168.2.7 255.255.255.0
duplex full
interface Ethernet2/1
ip address 192.168.60.7 255.255.255.0
duplex full
interface Ethernet2/2
no ip address
shutdown
duplex full
interface Ethernet2/3
no ip address
shutdown
duplex full
router eigrp 1
network 10.0.0.0
router ospf 1
network 192.168.60.0 0.0.0.255 area 0
network 192.168.102.0 0.0.0.255 area 0
network 192.168.200.7 0.0.0.0 area 0
router bgp 100
neighbor 192.168.200.2 remote-as 100
neighbor 192.168.200.2 update-source Loopback0
neighbor 192.168.200.5 remote-as 100
neighbor 192.168.200.5 update-source Loopback0
  neighbor 192.168.200.2 activate
  neighbor 192.168.200.2 send-community both
  neighbor 192.168.200.2 route-reflector-client
  neighbor 192.168.200.5 activate
  neighbor 192.168.200.5 send-community both
  neighbor 192.168.200.5 route-reflector-client
exit-address-family
address-family ipv4 vrf DC-1
  network 10.0.5.0 mask 255.255.255.0
  neighbor 10.0.5.9 remote-as 9000
  neighbor 10.0.5.9 activate
  neighbor 10.0.5.9 next-hop-self
exit-address-family
R9
hostname R9
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
interface Loopback0
ip address 10.9.255.9 255.255.255.255
no ip address
shutdown
duplex full
no ip address
duplex full
ip address 10.0.5.9 255.255.255.0
no ip address
duplex full
interface Ethernet1/1.200
ip address 10.0.6.9 255.255.255.0
shutdown
no ip address
shutdown
duplex full
no ip address
shutdown
duplex full
router eigrp 1
network 10.0.0.0
router bgp 9000
network 10.0.6.0 mask 255.255.255.0
network 10.9.255.9 mask 255.255.255.255
neighbor 10.0.5.7 remote-as 100
neighbor 10.0.6.8 remote-as 200
KS
hostname R12
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
ip ssh version 1
encr 3des
hash md5
group 2
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set LEVEL3-VPLS-TRANSFORM esp-3des esp-md5-hmac
mode transport
crypto ipsec profile LEVEL3-VPLS-PROFILE
set transform-set LEVEL3-VPLS-TRANSFORM
server local
  rekey lifetime seconds 300
  rekey retransmit 10 number 2
  rekey authentication mypubkey rsa MYKEY
  sa ipsec 1
   match address ipv4 private-traffic
   replay time window-size 5
interface Loopback0
ip address 172.16.50.12 255.255.255.255
no ip address
shutdown
duplex full
ip address 172.16.6.12 255.255.255.0
duplex full
there are five different router configurations in your post. Can you make a simple schematic drawing to indicate which router is connected to which router ?
See attached diagram
thanks for the diagram. I am labbing this in GNS3, will get back with you...
Where is R12 ? You posted the config, but it is not on your diagram...
R12 is the Key Server - Lo IP: 172.16.50.12/32
Thanks for looking into this for me
I labbed this in GNS3, and I am not sure if the access list you have configured is correct.. If you want to exclude LDP, BGP, and OSPF, and encrypt everything else, your access list should look like this:
deny ospf any any
permit ip any any
Obviously you might want to replace the 'any' with the ranges you have configured.
Can you give this a try ?
Hi Georg,
- I updated the ACL to looks like yours (See show crypto gdoi output on R7)
- I applied the Crypto MAP only on R7 - I did not applied it on R2 (LDP/MPLS/BGP are working - Which is the expected result). But I am still able to ping from R9 to R1 (Not expected) (See trace below - It traverses the MPLS)
In your LAB are you able to ping from R9 to R1 when you turn off GETVPN on R2?
R9#traceroute 10.1.255.1 source loopback 0
Tracing the route to 10.1.255.1
VRF info: (vrf in name/id, vrf out name/id)
  1 10.0.5.7 60 msec 60 msec 56 msec
  2 10.0.0.2 [AS 100] [MPLS: Label 26 Exp 0] 52 msec 56 msec 56 msec
  3 10.0.0.1 [AS 100] 76 msec 72 msec *
R7#sh crypto gdoi
GROUP INFORMATION
    Crypto Path              : ipv4
    Rekeys received          : 46
       Version               : 1.0.4
       Re-registers in       : 101 sec
       Unicast rekey received: 46
       Rekey ACKs sent       : 46
       Rekey Rcvd(hh:mm:ss)  : 00:01:07
    Rekeys cumulative
       Total received        : 46
       After latest register : 46
       Rekey Acks sents      : 46
   access-list   deny udp any any port = 646
   access-list   deny tcp any any port = 646
   access-list   deny tcp any any port = 179
   access-list   deny tcp any port = 179 any
   access-list   deny ospf any any
R2#sh crypto gdoi
GROUP INFORMATION
    Crypto Path              : ipv4
    Rekeys received          : 0
    Rekeys cumulative
       Total received        : 0
       After latest register : 0
       Rekey Received        : never
I'll check again, will get back with you...
how is the key server connected to the rest of your network? The only interface on R12 is:
duplex full
What is the corresponding connected interface on (what) other device ?
The easiest would be if you post the configuration of the routers at the other site as well, R4, R5, R6, and R8, that way, I can lab this end to end and also check the GM at the other site.
I attached the full diagram and the configuration file for each device (Except for R4). In your current lab, are you able to ping from one VRF to another VRF (CE to CE) crossing the MPLS while GETVPN is enabled on only one PE?
Great, I'll look into it further...
R1
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr aes
group 2
lifetime 300
interface Loopback0
negotiation auto
crypto map gdoimap
router eigrp 1
network 192.168.1.0
router ospf 1
router bgp 1
network 192.168.1.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
negotiation auto
negotiation auto
negotiation auto
router eigrp 1
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
router ospf 1
router bgp 2
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr aes
group 2
mode tunnel
server local
sa ipsec 1
profile profile1
no replay
interface Loopback0
negotiation auto
router eigrp 1
network 192.168.3.0
router ospf 1
router bgp 3
network 192.168.3.0
no ip http server
deny ospf any any
permit ip any any
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R4
version 15.2
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr aes
group 2
lifetime 300
interface Loopback0
negotiation auto
crypto map gdoimap
router eigrp 1
network 192.168.2.0
router ospf 1
router bgp 4
network 192.168.2.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
