Cisco GETVPN over MPLS Issue
mediaos718
I have 2 sites connected over MPLS.
R1 is the CE router (Network: 10.0.0.0/8)
R2 is the PE router in SITE-1 (Using network: 192.168.0.0/16 and 172.16.0.0/16
R7 is PE the router in SITE-2 (Using network: 192.168.0.0/16 and 172.16.0.0/16)
R9 is the CE router in SITE-2 (Using network: 10.0.0.0/8)
Key Server and Certificate Server are using network 172.16.0.0/16
I enabled GETVPN on R7 only.
I configured an access-list on the Key Server (KS) to:
1) Not to encrypt BGP between the PEs (R2 and R7)
2) Not to encrypt OSPF traffic between the PEs (R2 and R7)
3) Not to Encrypt LDP traffic between the PEs (R2 and R7)
Since I enabled GETVON on only SITE-2, I should not be able to ping between the CE routers.
- The problem is that I am able to ping between the CE's.
- The only time that I am unable to ping between the CE is when I modify the ACL on the Key server encrypt (BGP or OSPF or LDP).
- Observation: GETVPN is encrypting the BGP, OSPF, and the LDP (on the 192.168.0.0/16 and 172.16.0.0/16) but not traffic on the (10.0.0.0/8)
Please let me know I am doing wrong here. I will send config and show output upon request.
R7#sh crypto gdoi
GROUP INFORMATION
    Group Name               : LEVEL3-VPLS-GROUP
    Group Identity           : 1234
    Crypto Path              : ipv4
    Key Management Path      : ipv4
    Rekeys received          : 19
    IPSec SA Direction       : Both
     Group Server list       : 172.16.50.12
    Group member             : 192.168.200.7    vrf: None
       Version               : 1.0.4
       Registration status   : Registered
       Registered with       : 172.16.50.12
       Re-registers in       : 140 sec
       Succeeded registration: 1
       Attempted registration: 1
       Last rekey from       : 172.16.50.12
       Last rekey seq num    : 0
       Unicast rekey received: 19
       Rekey ACKs sent       : 19
       Rekey Rcvd(hh:mm:ss)  : 00:00:46
       allowable rekey cipher: any
       allowable rekey hash  : any
       allowable transformtag: any ESP
    Rekeys cumulative
       Total received        : 19
       After latest register : 19
       Rekey Acks sents      : 19
ACL Downloaded From KS 172.16.50.12:
   access-list   deny ip 192.168.0.0 0.0.255.255 host 224.0.0.2
   access-list   deny ip 192.168.0.0 0.0.255.255 host 224.0.0.3
   access-list   deny ip 192.168.0.0 0.0.255.255 host 224.0.0.4
   access-list   deny ip 192.168.0.0 0.0.255.255 host 224.0.0.5
   access-list   deny ip 192.168.0.0 0.0.255.255 host 224.0.0.6
   access-list   deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
   access-list   deny ip 172.16.0.0 0.0.255.255 172.16.0.0 0.0.255.255
   access-list   permit ip any any
KEK POLICY:
    Rekey Transport Type     : Unicast
    Lifetime (secs)          : 252
    Encrypt Algorithm        : 3DES
    Key Size                 : 192
    Sig Hash Algorithm       : HMAC_AUTH_SHA
    Sig Key Length (bits)    : 512
TEK POLICY for the current KS-Policy ACEs Downloaded:
  Ethernet1/2:
    IPsec SA:
        spi: 0xA36FCACE(2742012622)
        transform: esp-3des esp-md5-hmac
        sa timing:remaining key lifetime (sec): (780)
        Anti-Replay(Time Based) : 5 sec interval
20 Replies 20
I only see the issue when I add GETVPN on top of MPLS (I am not sure whether this is a GNS limitation).
I have a similar setup as yours - It works.
The issue was with GNS - It runs on VIRL
good to know, thanks for the info !
I'm running Cisco CML and I'm not able to run GETVPN over MPLS either but if I have routers connected to a switch GETVPN works fine. I'm trying to configure this w/o our ISP having to configure anything on their side that's why we're using unicast vs multicast keys. I'm deploying this in production next week I'll see if it's CML causing the issue or my configuration.
post the configuration you have...
When I attach the crypto map to the GM's MPLS internet it does not receive the key from the KS but if I apply the crypto map to the loopback interface the keys are received. From a host PC (a switch) at the GM I'm able to ping the KS and other branches but I don't see encypts or decrypts on the GM. Below are my configs MPLS-PE1, KS1, MPLS-PE5, GM1, MPLS-PE6, GM2:
