Cisco IOS XR - redistribute from BGP to OSPF filtering on community.
jvoorend
I am wanting to filter routes from BGP to OSPF based on the BGP community:
Have the following setup:
community-set GLF_Local_910
  910:910
end-set
route-policy BGP-To-CMN
  if community matches-any GLF_Local_910 then
    pass
  else
    drop
  endif
end-policy
When I apply the following to the ospf process:
redistribute bgp 4288888888 tag 660 route-policy BGP-To-CMN
I get the following:
router ospf 10
!!% Could not find entry in list: Policy [BGP-To-CMN] uses the 'community' attribute. There is no 'community' attribute at the ospf redistribution attach point.
Is there a way under IOS XR to filter from BGP to OSPF based on the community ?
Kind Regards
John
5 Replies 5
balaji.bandi
jvoorend
Thank you for that - I actually saw that thread however:
Mention is made of the below as a solution:
"You could set a tag based on the community using a table-policy under the proper address-family and then use this tag to conditionally redistributed the routes in OSPF"
What is a "table-policy" and do you have an example of this ?
Kind Regards
Hi @jvoorend ,
The table-policy is configured to filter routes from the BGP local rib to the routing table. What you want to achieve would look something like this.
route-policy bgp2rib
if community matches-any (xxx:xxx) then
set tag 999
endif
end-policy
route-policy rib2ospf
if tag eq 999 then
pass
endif
end-policy
router ospf xxx
redistribute bgp xxx route-policy rib2ospf
router bgp xxx
address-family ipv4 unicast
table-policy bgp2rib
jvoorend
Many thanks for that - it worked a treat.
Kind Regards
John
