Cisco IPSec VTI VPN Behind a NAT Device
mrmadgig
I have a few questions pertaining to the title of the post.
Are VTI VPN on Cisco Router capable of being behind another PAT / NAT device? AKA Router.
If so.... on the Tunnel interface of the router behind the nat device with a private IP do you set the tunnel source to private IP interface? Or the public of the nat router?
I am new at the NAT-T config and not being very successful with this config so I wanted to ask if this version VPN will work or do  I need policy based.
Thank you
Joseph
the tunnel source needs to be the outgoing interface (private IP address).
Have a look at the link below, which has a pretty comprehensive sample configuration:
IPSec VPNs on Cisco routers when both are behind NAT
https://layer77.net/2019/07/12/ipsec-vpns-on-cisco-routers-when-both-are-behind-nat/comment-page-1/
Wow thanks fort the response. I never got a notification. This is why I it took so long for reply.
I have not read the doc yet but I will here shortly. I have been having issues with both a Router isr4331 and and ASA that I put between these routers and not one will let go of the ports 500 or 4500 always get error that Either reserved by the system or cannot reserve ports.
So not sure how I am going to nat this. Also what is weird when I debug crypto isakmp the output never shows NAT detected and never  switches to port 4500
So to be clear is this correct?
This is the Tunnel interface of the router behind the ASA. Please note that I had this same situation with a isr4331 before I decided to try with an ASA and I still get no tunnel up
So you saying to change the tunnel source to the private ip? Of what the WAN private IP of the VPN router ? the WAN ip of this router is 192.168.117.254
interface Tunnel1
ip address 172.16.200.2 255.255.255.252
zone-member security MAIN-LAN
tunnel source 73.xxx.160.27
tunnel mode ipsec ipv4
tunnel destination 50.xxx.102.118
tunnel protection ipsec profile protect-VTI
