Cisco ISR 4321 and GLC-T
datamodule
We have Cisco ISR 4321 router and this one came with spare SFP port and planning to install GLC-T RJ45 sfp module in to this.I have installed this and this recognized the media.
Auto Duplex, Auto Speed, link type is auto, media type is RJ45
My question is does this mean it will support the routing on this interface and work like normal interface.
Thanks for your help.
8 Replies 8
Mark Elsen
 - It should , you can also verify optics compatibility here :
              https://tmgmatrix.cisco.com/home
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
what does the interface show up like in the running config ?
If it looks like this:
interface GigabitEthernet 0/1/0
no ip address
it is a routable interface...
Seeing in running config for the interface
interface GigabitEthernet0
ip address 172.30.235.10 255.255.255.224
negotiation auto
GigabitEthernet0 is the management interface I think...
Can you post the output of:
show ip interface brief
From the above table it does support so routing should work as noraml.
The compatibility matrix only shows you if the module is compatible, it does not say anything about layer 2 or layer 3 capability. With module inserted, post the output of 'sh run'...
datacenter
Hi Guys, I'm facing the same "issue". I just plugged the GLC-T, but I can't see the interface.
Did you guys solve it?
inderdeeps
Level 4
Level 4
Yes it will as the feature depends upon the Device and you can check the device features on the below tool
https://cfnng.cisco.com/
This tool helps to find all the feature supported on the device. explore and you will get to know more
Inderdeep Singh
www.thenetworkdna.com
"Rate the reply if you think it helps"
