Cisco ISR 4431 IP Base License BGP and SSH support?
YHam
Hello all,
I'm going to order ISR4431/K9 and wanted to confirm if the license i have in the quote support BGP and SSH. I checked at Cisco Feature Navigator  and looks like those features are available in IP Base license SL-44-IPB-K9 with IOS-XE Universal SISR4400UK9-166. Just want to double check with experts here. See the screenshot of Feature Navigator. Thanks.
Here are part numbers
- ISR4431/K9 - Cisco ISR 4431 (4GE,3NIM,8G FLASH,4G DRAM,IPB)
- SL-44-IPB-K9  - IP Base License for Cisco ISR 4400 Series
- SISR4400UK9-166 - Cisco ISR 4400 Series IOS XE Universal
Leo Laohoo
What firmware is the router meant to be loaded with?
Starting from 16.9.X (and later), all appliances (from routers, switches, WLC, etc.) will now be Cisco Smart Licensing (CSL).
I listed the part numbers in my post above that I'm getting in the Quote. When I select IP Base as FeatSet, IOS-XE, latest release and ISR4431 in feature navigator, It shows the Image name (see the screenshot in my post above) and the available features. I see BGP and SSH there.
I wanted someone here to confirm that the IP base has those features and I don't need some advanced license to run BGP/SSH etc.
Thanks.
j.a.m.e.s
Level 4
Level 4
HI YHam,
Based on your screenshot, I think IPBase on the ISR4431 includes BGP routing and allows BFD use with it as well.
James.
