Router cannot reach its own interface
Jonathan Nali
Hi Everyone,
I always get help from this forum so I am confident an solution will be found here.
I have this Cisco Router 891
I have put IP addresses on gig0 - 192.168.124.10 and FE8 - 10.10.3.3,
I can ping FE  8 but not Gig0. Do not know why. Maybe you can see something I am missing.
When I plug in an ethernet cable, it response to say, interface is up.
ip source-route
ip dhcp relay information option
ip dhcp relay information trust-all
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.3.253
ip dhcp excluded-address 10.10.3.252
ip dhcp excluded-address 10.10.3.1 10.10.3.50
ip dhcp pool KITWE-POOL
network 10.10.3.0 255.255.255.0
default-router 10.10.3.3
dns-server 10.10.1.4
ip cef
no ip domain lookup
ip name-server 8.8.8.8
no ipv6 cef
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
ip dhcp relay information option-insert
ip address 10.10.3.3 255.255.255.0
ip helper-address 10.10.3.3
ip directed-broadcast
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0
description Internet
ip address 192.168.124.10 255.255.255.252
ip helper-address 192.168.124.10
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip forward-protocol udp talk
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 111 interface GigabitEthernet0 overload
ip nat outside source static 10.10.1.0 10.10.3.3
ip nat outside source static 192.168.124.2 192.168.124.10
ip route 0.0.0.0 0.0.0.0 192.168.124.1 2
ip route 192.168.124.0 255.255.255.252 192.168.124.9
ip route 192.168.124.0 255.255.255.252 GigabitEthernet0 3
access-list 111 deny ip 10.10.3.0 0.0.0.255 10.10.1.0 0.0.0.255
access-list 111 permit ip 10.10.3.0 0.0.0.255 any
no cdp run
5 Replies 5
balaji.bandi
What is the source IP you trying to ping ?
can you share ipconfig /all information from the device ? (if windows)
BB
remove the lines marked in bold:
ip source-route
domain-name repro.local
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
license udi pid CISCO891-K9 sn FCZ1544C41L
username kitwert privilege 15 secret 5 $1$W.GL$N7EAtQPVUmtdxuRdLvwGa.
interface Loopback0
ip nat inside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
interface Async1
no ip address
encapsulation slip
no ip http server
--> no ip nat outside source static 10.10.1.0 10.10.3.3
--> no ip nat outside source static 192.168.124.2 192.168.124.10
--> no ip route 192.168.124.0 255.255.255.252 192.168.124.9
--> no ip route 192.168.124.0 255.255.255.252 GigabitEthernet0 3
--> no access-list 111 deny ip 10.10.3.0 0.0.0.255 10.10.1.0 0.0.0.255
no cdp run
Hello
no ip helper-address 192.168.124.10 <-- not required
ip directed-broadcast <-- why do you require this?
ip helper-address 10.10.3.3 <---- not required
no ip route 192.168.124.0 255.255.255.252 192.168.124.9 <-not required connected interface
no ip route 192.168.124.0 255.255.255.252 GigabitEthernet0 3  < - not required connected interface
no ip route 0.0.0.0 0.0.0.0 192.168.124.1 2 < recursive lookup for nexthop
ip source-route < -- let the rtr make the forwarding decision not the source
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 192.168.124.1 2 < disables recursive lookup for nexthop
Kind Regards
Paul
Can i get a show ip route output.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
We have several responses which suggest  changes in the config. While I agree that these suggestions are appropriate ways to improve the config, I do not see that they relate to problems to ping G0. I agree that the output of show ip route may be helpful but think that output of these commands would be more helpful
show ip interface brief
show arp
Rick
