cisco ISR4321 NAT
nurbol555
i have on port Gi0/0/0 three sub interface, two of them inside LAN network, last one internet interface, i use NAT from LAN addres to internet throw internet interface address and it worked, after that i'm added other LAN sub interface and my NAT stoped working, when i'm deleted one of this LAN port NAT again worked, what's problem?
interface GigabitEthernet0/0/0.5
encapsulation dot1Q 5
ip address 172.30.6.2 255.255.255.0
ip nat inside
interface GigabitEthernet0/0/0.10
encapsulation dot1Q 10
ip address 172.40.6.2 255.255.255.0
ip nat inside
interface GigabitEthernet0/0/0.20
encapsulation dot1Q 20
ip address 172.50.6.2 255.255.255.0
ip nat inside
interface GigabitEthernet0/0/0.899
description INET
encapsulation dot1Q 899
ip address x.x.10.10    255.255.255.252
ip nat outside
ip nat inside source static 172.40.6.80 x.x.10.10
7 Replies 7
what happens if you change:
to
ip nat inside source static 172.40.6.80 interface GigabitEthernet0/0/0.899
Doesn't support that command, only ip address to ip address, i was wondered when i find out that on isr4321
odd. What IOS version are your running on your router ? Does:
ip nat inside source static tcp 172.40.6 80 interface GigabitEthernet0/0/0.899 80
work ?
Can you post the full config of your router ?
IOS version 15.5,  command  ip nat inside source static tcp 172.40.6 80 interface GigabitEthernet0/0/0.899 80 doesn't work and doesn't support, full version can show on monday, but what i wrote above it's  the main config what we need
as far as I remember, the 4321 started with IOS 16.3, so I am not sure if 15.5 even works.
The latest release is the 3.16 IOS XE, can you try and upgrade to this version, or the 16.3 or the 16.3 version ?
https://software.cisco.com/download/release.html?mdfid=286006221&softwareid=282046477&release=3.13.1S
i just find out my router isr4321 had autoconfig, i see autoconfig first time, and now it support nat from interface GigabitEthernet0/0/0.899, who knows more about autoconfig? Is it dangerous? Is it downland config from internet?
are you referring to 'vlan-autoconfig' (which would be downloaded from a RADIUS server) ?
