Showing results forĀ
Search instead forĀ
Did you mean:Ā
BGP route-map to filter default route with specific RT but allow all prefixes from other VRF's
smailmilak
Level 4
Level 4
I am trying to create a route-map on IOS 122-33.SRE11 where I want to achieve this:
Allow only default route from RT 65101:50
Allow all routes from RT 65101:609 and 65101:10
I have a preflix-list with 0.0.0.0/0 for the default route in Route-map sequence 10 where I match the prefix-list and extcommunity list with RT 65101:50.
Second sequence is with with ext-community list with RT 65101:609 and 65101:10
Problem is that the route-map filters all routes that are not in the prefix-list. I want that the router checks the prefix-list only for RT 65101:50.
I have tried everything but whatever I do the router is denying all other routes except 0.0.0.0/0.
Workaround is to have the prefixes in the preflix-list I want to allow but this is not scalable.
On IOS-XR with RPL it's simple and I have accomplished this.
5 Replies 5
Hello
Do you have extended communities enabled?
Can you post the config please of your route-map and prefix-list
res
Paul
Kind Regards
Paul
do you mean extended communities between the BGP neighbors? Yes.
Here is one of the multiple configs I have tried to use.
ip prefix-list DEF_ONLY
seq 5 permit 0.0.0.0/0
ip extcommunity-list standard INTERNET_VRF permit rt 65101:50
ip extcommunity-list standard INTERNAL_VRF permit rt 65101:10 rt 65101:609
route-map IGW_FILTER permit 10
match extcommunity INTERNAL_VRF
continue 30
route-map IGW_FILTER permit 15
match ip address prefix-list DEF_ONLY
match extcommunity INTERNET_VRF
continue 30
route-map IGW_FILTER permit 30
route-map IGW_FILTER deny 40
Hi Dude,
Can you try creating route-maps withouth "continue" statement and check.
Hitesh
Hitesh Vinzoda
Level 4
Level 4
Hi Dude,
I suggest that you call a prefix list in permit 20 which is 0.0.0.0/0 le 32 and see if that helps.
Hitesh
using 0.0.0.0/0 le 32 in seq 20 allows all routes. Maybe I am doing it wrong?
ip prefix-list DEF_ONLY_TEST: 1 entries
ip prefix-list INTERNAL_VRF: 1 entries
seq 5 permit 0.0.0.0/0 le 32
route-map IGW_FILTER_TEST, permit, sequence 10
Match clauses:
ip address prefix-lists: DEF_ONLY_TEST
extcommunity (extcommunity-list filter):INTERNET_VRF
Set clauses:
Policy routing matches: 0 packets, 0 bytes
route-map IGW_FILTER_TEST, permit, sequence 15
Match clauses:
ip address prefix-lists: INTERNAL_VRF
Set clauses:
route-map IGW_FILTER_TEST, deny, sequence 40
Match clauses:
Set clauses:
