Cisco ISR4331/K9 Router with NIM-ES2-4
When i want to add NIM-ES2-4 Interface Card in the ISR4431/K9 Router in CCW, the Error is showing 'A selection of SSD is required when NIM-SSD is selected.'
is it necessary to add NIM-SSD when selecting NIM-ES2-4. ?
Can i just add NIM-ES2-4 as spare (ignoring the NIM-SSD Selection) ?
Urgent Suggestion Required.
2 Accepted Solutions
I would say this is a new bug in the Commerce Workplace tool, as I have not had that issue before.
So yes, I would select it as a spare.
was facing the same issue..
definitely an issue in CCW.
7 Replies 7
Philip D'Ath
You don't need add NIM-SSD for a NIM-ES2-4.  You can just add NIM-ES2-4.
The error message in your screenshot shows you have selected a NIM-SSD - which obviously needs an SSD to make it a complete configuration.
Dear Philip
Thank you so much for your reply.
Please find the attachment showed in my previous post, i did not select NIM-SSD.  I just select the NIM-ES2-4, However it shows the error.
So that can i select NIM-ES2-4 as a spare ?
Appreciate your Answer.
Thank you so much for your opinion.
Probably a CCW bug. I just experienced the same issue on a previously valid build.
Finally Problem Solved...i'm so happy..now i can select NIM-ES2-4 Card without any error.
Thanks everyone.
