IPSEC VPN TWO Cisco router not connecet
hello i have problem to connected two cisco device ipsec vpn.
one side cisco have multiple vpn connections and gre tunels i don't know if there are problem or my router i have sh run two router
R1
#sh run
Building configuration...
Current configuration : 13039 bytes
! Last configuration change at 14:11:53 Tbilisi Wed Jul 4 2018 by admin
! NVRAM config last updated at 14:40:04 Tbilisi Sat Jun 16 2018 by admin
version 15.5
no platform punt-keepalive disable-kernel-core
hostname EMSC
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 $1$GvBy$.XsD4VRpxLcXxhhR3ebPa0
aaa new-model
aaa session-id common
clock timezone Tbilisi 4 0
ip name-server $$$$$$$$$$$$$$$
ip domain name yourdomain.com
no ip dhcp use vrf connected
ip dhcp excluded-address 10.195.195.1 10.195.195.50
ip dhcp excluded-address 10.195.195.180 10.195.195.254
ip dhcp excluded-address 10.195.195.156
ip dhcp excluded-address 10.195.195.66
ip dhcp excluded-address 10.195.195.253
ip dhcp excluded-address 10.195.195.248
ip dhcp excluded-address 10.195.195.249
ip dhcp excluded-address 10.195.195.247
ip dhcp excluded-address 10.195.195.246
ip dhcp excluded-address 10.195.195.245
ip dhcp excluded-address 10.195.195.243
ip dhcp excluded-address 10.195.195.241
ip dhcp excluded-address 10.195.195.242
ip dhcp excluded-address 10.195.195.252
ip dhcp excluded-address 10.195.195.236
ip dhcp excluded-address 10.195.195.237
ip dhcp excluded-address 10.195.195.221
ip dhcp excluded-address 10.195.195.222
ip dhcp excluded-address 10.195.195.230
ip dhcp excluded-address 10.195.195.231
ip dhcp excluded-address 10.195.195.232
ip dhcp excluded-address 10.195.195.234
ip dhcp excluded-address 10.195.195.148
ip dhcp excluded-address 10.195.195.142
ip dhcp excluded-address 10.195.195.159
ip dhcp excluded-address 10.195.195.239
ip dhcp excluded-address 10.195.195.238
ip dhcp pool lan
 network 10.195.195.0 255.255.255.0
 dns-server $$$$$$$$$$$$$$$$$$$$$$$$$$
 default-router 10.150.150.1
subscriber templating
license udi pid ISR4321/K9 sn FDO20060ZBD
username sa privilege 15 secret 5 $1$Q6/F$KdKUW7P8aLsnBojUpbWHu/
username admin privilege 15 secret 5 $1$mxJ4$HckDyjlAIr4JMMR9ngLYK.
redundancy
 mode none
vlan internal allocation policy ascending
no cdp run
track 1 ip sla 1 reachability
 delay down 2 up 5
track 2 ip sla 2 reachability
 delay down 2 up 5
crypto isakmp policy 5
 encr 3des
 authentication pre-share
 group 2
 lifetime 3600
crypto isakmp policy 10
 encr aes
 group 2
crypto isakmp policy 45
 encr aes 256
 group 2
 lifetime 28800
crypto isakmp policy 101
 encr 3des
 hash md5
 group 2
crypto isakmp ^^^^^^^
crypto isakmp k^^^^^^^^^^^^^^
crypto isakmp key^^^^^^^^^^^^^
crypto isakmp key ^
crypto isakmp key ^^^^^^^^^^^^^^^^^^^^
crypto isakmp key ^^^^^^^^^^^^^^^^^^^^^^^h
crypto isakmp key s^^^^^^^^^^^^^^^^^^^^^^^
crypto isakmp key ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
crypto isakmp key u^^^^^^^^^^^^^^^^^^
crypto isakmp ^^^^^^^^^^^^^^^^^^^^^^^^^
crypto isakmp key VPNdosoEM@!# address 81.16.245.206
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set aes128-sha esp-aes esp-sha-hmac
 mode tunnel
crypto ipsec transform-set 3des-sha esp-3des esp-sha-hmac
 mode tunnel
crypto ipsec transform-set DOSOVPN esp-3des esp-md5-hmac
 mode tunnel
crypto ipsec profile 3des-sha
 set transform-set 3des-sha
crypto ipsec profile aes128-sha
 set transform-set aes128-sha
crypto map CryptoDeltanet 5 ipsec-isakmp
 description simulation
 set peer
 match address EMSC-Simulat
crypto map CryptoDeltanet 55 ipsec-isakmp
 set peer 81.16.245.206
 set transform-set DOSOVPN
 match address VPN-DOSO
crypto map DOSO 11 ipsec-isakmp
 set peer
 match address DOSOVPN
interface Tunnel10
 description TO_112
 ip address 172.30.0.1 255.255.255.252
 ip tcp adjust-mss 1350
 tunnel source
 tunnel mode ipsec ipv4
 tunnel destination
 tunnel path-mtu-discovery
 tunnel protection ipsec profile aes128-sha
interface Tunnel11
 description TO_MOLHSA
 ip address 172.40.0.202 255.255.255.252
 tunnel source
 tunnel destination
interface Tunnel18
 description AKA1
 ip address 172.50.0.1 255.255.255.252
 ip nat outside
 tunnel source GigabitEthernet0/0/0
 tunnel destination 188.169.44.234
 tunnel protection ipsec profile 3des-sha
interface Tunnel100
 description TO_Magticom
 ip address 10.17.1.66 255.255.255.252
 tunnel source
 tunnel destination
interface Tunnel111
 description Magticom-VOIP
 ip address 10.33.14.38 255.255.255.252
 tunnel source
 tunnel destination 8
interface Tunnel122
 description DES
 ip address 172.21.1.154 255.255.255.252
 ip nat outside
 tunnel source
 tunnel destination 178.249.18.1
interface Tunnel188
 description AKA2
 ip address 172.51.0.1 255.255.255.252
 ip nat outside
 tunnel source GigabitEthernet0/0/1
 tunnel destination
interface Tunnel210
 description TO_112_2
 ip address 172.16.120.2 255.255.255.252
 tunnel source
 tunnel destination
interface Tunnel1111
 description Magticom-VoipFromSilk
 ip address 10.33.14.46 255.255.255.252
 tunnel source
 tunnel destination 81.95.167.53
interface GigabitEthernet0/0/0
 description ISP1
 ip address 252
 ip nat outside
 negotiation auto
 ip virtual-reassembly
interface GigabitEthernet0/0/1
 description ISP2
 ip address 255.255.255.252
 ip nat outside
 negotiation auto
interface GigabitEthernet0/1/0
 switchport access vlan 90
 shutdown
 speed 100
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
 speed 100
interface GigabitEthernet0/1/3
 switchport access vlan 2
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface Vlan1
 description LAN
 ip address 10.195.195.1 255.255.255.0
 ip nat inside
 ip tcp adjust-mss 1452
interface Vlan2
 description Region
 ip address 10.17.3.1 255.255.255.0
ip local policy route-map ISP_loop
ip nat inside source static tcp 10.195.195.232 3389 interface GigabitEthernet0/0/0 20005
ip nat inside source static tcp 10.195.195.159 3389 interface GigabitEthernet0/0/0 20002
ip nat inside source static tcp 10.195.195.142 3389 interface GigabitEthernet0/0/0 20001
ip nat inside source static tcp 10.195.195.148 3389 interface GigabitEthernet0/0/0 20000
ip nat inside source static tcp 10.195.195.66 3389 interface GigabitEthernet0/0/0 16001
ip nat inside source static tcp 10.195.195.235 3389 interface GigabitEthernet0/0/0 3389
ip nat inside source static tcp 10.195.195.207 47 interface GigabitEthernet0/0/0 47
ip nat inside source static tcp 10.195.195.207 1723 interface GigabitEthernet0/0/0 1723
ip nat inside source static tcp 10.195.195.16 3389 interface GigabitEthernet0/0/0 2277
ip nat inside source static tcp 10.195.195.156 3389 interface GigabitEthernet0/0/0 16000
ip nat inside source list 150 interface GigabitEthernet0/0/0 overload
ip nat inside source list nat_to_napr interface Tunnel122 overload
ip nat inside source route-map ISP1 interface GigabitEthernet0/0/0 overload
ip nat inside source route-map ISP2 interface GigabitEthernet0/0/1 overload
ip forward-protocol nd
ip ftp username cisco
ip ftp password cisco123
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 92.51.76.53 100 track 1
ip route 0.0.0.0 0.0.0.0 37.232.96.185 150 track 2
ip route 10.10.112.0 255.255.255.0 172.30.0.2 name TO_112_Servers
ip route 10.16.21.0 255.255.255.0 10.17.1.65
ip route 10.60.226.11 255.255.255.255 172.30.0.2 name To_112_Servers
ip route 10.60.226.14 255.255.255.255 172.30.0.2 name To_112_Servers
ip route 10.120.121.0 255.255.255.0 92.51.79.142 name simulation
ip route 81.95.160.47 255.255.255.255 81.95.160.245 name magti
ip route 81.95.167.53 255.255.255.255 37.232.96.185
ip route 81.95.168.22 255.255.255.255 10.33.14.37 name Magticom-VOIP
ip route 81.95.168.22 255.255.255.255 10.33.14.45 10 name Magticom-VOIP
ip route 178.249.17.1 255.255.255.255 92.51.76.53 name NAPR_Tunnel_Route
ip route 178.249.17.129 255.255.255.255 172.21.1.153 name NAPR_Des_Server
ip route 178.249.20.59 255.255.255.255 172.21.1.153 name NAPR_HR_Server
ip route 192.168.1.0 255.255.255.0 Tunnel18 name to_MPSAKA1
ip route 192.168.1.0 255.255.255.0 Tunnel188 name to_MPSAKA188
ip access-list extended DOSOVP
ip access-list extended DOSOVPN
 permit ip 10.195.195.0 0.0.0.255 192.168.250.0 0.0.0.255
ip access-list extended EMSC-Simulat
 permit ip 10.195.195.0 0.0.0.255 10.120.121.0 0.0.0.255
ip access-list extended INBOUND
 permit ip host 109.238.235.182 host 10.195.195.252
 permit ip any any
ip access-list extended NAT
 deny   ip 10.195.195.0 0.0.0.255 10.120.121.0 0.0.0.255
 deny   ip 10.195.195.0 0.0.0.255 host 10.60.226.11
 deny   ip 10.195.195.0 0.0.0.255 host 10.60.226.14
 deny   ip 10.195.195.0 0.0.0.255 10.10.112.0 0.0.0.255
 deny   ip 10.195.195.0 0.0.0.255 host 178.249.20.59
 deny   ip host 10.195.195.195 host 178.249.17.129
 deny   ip 10.195.195.0 0.0.0.255 host 178.249.17.129
 deny   ip host 10.195.195.150 host 178.249.17.129
 deny   ip host 10.195.195.40 host 178.249.17.129
 deny   ip host 10.195.195.41 host 178.249.17.129
 permit ip 10.195.195.0 0.0.0.255 any
 deny   ip 10.195.195.0 0.0.0.255 192.168.247.0 0.0.0.255
ip access-list extended NAT2
 deny   ip 10.195.195.0 0.0.0.255 any
 permit ip host 10.195.195.160 any
ip access-list extended VPN-DOSO
 permit ip 10.195.195.0 0.0.0.255 192.168.247.0 0.0.0.255
ip access-list extended nat_to_napr
 permit ip 10.195.195.0 0.0.0.255 host 178.249.20.59
 permit ip host 10.195.195.195 host 178.249.17.129
 permit ip host 10.195.195.150 host 178.249.17.129
 permit ip host 10.195.195.40 host 178.249.17.129
 permit ip host 10.195.195.41 host 178.249.17.129
 permit ip 10.195.195.0 0.0.0.255 host 178.249.17.129
ip sla 1
 icmp-echo 92.51.76.53 source-interface GigabitEthernet0/0/0
 request-data-size 32
 frequency 5
 history hours-of-statistics-kept 24
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 37.232.96.185 source-interface GigabitEthernet0/0/1
 frequency 5
ip sla schedule 2 life forever start-time now
access-list 102 permit tcp host 10.195.195.202 any eq smtp
access-list 102 deny   tcp any any eq smtp
access-list 102 permit ip any any
access-list 150 deny   ip 10.195.195.0 0.0.0.255 192.168.247.0 0.0.0.255
access-list 150 permit ip 10.195.195.0 0.0.0.255 any
access-list 2000 remark ISP1_Loop
access-list 2000 permit ip host 92.51.76.54 any
access-list 2001 remark ISP2_Loop
access-list 2001 permit ip host 37.232.96.186 any
route-map ISP_loop permit 1
 match ip address 2000
 set ip next-hop 92.51.76.53
route-map ISP_loop permit 2
 match ip address 2001
 set ip next-hop 37.232.96.185
route-map LocalPolicy permit 100
 match ip address NAT
 match interface GigabitEthernet0/0/0
 set ip next-hop verify-availability 92.51.76.53 1 track 1
route-map LocalPolicy permit 110
 match ip address NAT2
 match interface GigabitEthernet0/0/1
 set ip next-hop verify-availability 37.232.96.185 20 track 2
route-map ISP2 permit 1001
route-map ISP1 permit 1000
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 privilege level 15
 transport input telnet ssh
scheduler max-task-time 5000
ntp server 176.58.109.199
event manager applet natclear
 event track 1 state any
 action 0.9 cli command "enable"
 action 1.0 cli command "clear ip nat translation *"
 action 2.0 cli command "clear ip nat translation forced"
end
 and
R2
Current configuration : 2435 bytes
version 12.4
hostname doso
boot-start-marker
boot-end-marker
enable secret 5 $1$TFVW$jcIdNpb8rMm9pWZN5Lnns/
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
 encr 3des
 group 2
crypto isakmp policy 50
 encr aes
crypto isakmp policy 55
 encr 3des
 hash md5
 group 2
crypto isakmp key address 109.238.235.226
crypto isakmp key VPNdosoEM@!# address 92.51.76.54
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set VPNEMC esp-3des esp-md5-hmac
crypto map PRIMEVPN 15 ipsec-isakmp
 set peer 109.238.235.226
 set transform-set 3DES-SHA
 set pfs group2
 match address 100
crypto map PRIMEVPN 20 ipsec-isakmp
 ! Incomplete
crypto map PRIMEVPN 60 ipsec-isakmp
 set peer 92.51.76.54
 set transform-set VPNEMC
 match address VPN-EMC
interface FastEthernet0/0
 mac-address 0023.5e39.20b7
 ip address dhcp
 ip access-group 102 in
 ip nat outside
 ip policy route-map NONAT
 duplex auto
 speed auto
 crypto map PRIMEVPN
interface FastEthernet0/1
 ip address 192.168.247.254 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route 192.168.250.0 255.255.255.0 192.168.247.253
ip http server
ip nat inside source list 150 interface FastEthernet0/0 overload
ip nat inside source route-map NONAT interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.250.12 3389 interface FastEthernet0/0 3389
ip access-list extended VPN-EMC
 permit ip 192.168.247.0 0.0.0.255 10.195.195.0 0.0.0.255
access-list 100 permit ip 192.168.247.0 0.0.0.255 10.130.130.0 0.0.0.255
access-list 100 permit ip 10.130.130.0 0.0.0.255 192.168.247.0 0.0.0.255
access-list 103 permit tcp any eq 3389 any
access-list 110 deny   ip 192.168.247.0 0.0.0.255 10.130.130.0 0.0.0.255
access-list 110 permit ip 192.168.247.0 0.0.0.255 any
access-list 110 deny   ip 192.168.247.0 0.0.0.255 10.195.195.0 0.0.0.255
route-map NONAT permit 10
 match ip address 110
control-plane
line con 0
line aux 0
line vty 0 4
 password
 login
end
a.alekseev
Level 7
Level 7
There is no good to mix crypto-map and SVTI.
So my advice is to reconfigure your crypto-map to SVTI
this rotuer not mine side and using multiple vpns and gre tunels how i can easly connecet this two router ipsec vpn ?
