Cisco Nexus 5000 Series
Dear All,
Can anyone tell me that either is there any cisco nexus 5000 series which supports layer 3 routing (ip routing, static routing and routing protocols) also supports qos dscp on interface? please mention the model number for these features in nexus 5000 series.
cofee
Level 5
Level 5
Look up Nexus 5672. There has to be more models in the NX 5000 series, but it crossed my mind because I have used it briefly in the past.
https://www.cisco.com/c/en/us/support/switches/nexus-5672up-switch/model.html
Thank you for your reply. I have seen this model but I want to know that this command works on its interfaces or not. "mls qos trsut dscp". Please check on your interface if you have nexus. Looking forward for your positive reply.
Unfortunately I don't have access to this specific model, but you should be able to find out if the command is supported by reading configuration/commands guide of the system image for this model.
thanks i will check this out.
