Cisco qos on 6500
Michele Toblini
Hello guys,
I'm working for the very first time on a 6500. This is the IOS "
Cisco IOS Software, s2t54 Software (s2t54-ADVIPSERVICESK9_NPE-M), Version 15.0(1)SY4, RELEASE SOFTWARE (fc3)"
Could you give me some infos about qos?
mls qos is not working, qos map dscp or cos too... I'm kinda lost.
mtsb
Hi Michele,
I have not worked extensively on QoS on SUP2T either but for the SUP2T supervisor type you will not see the mls commands as the architecture and forwarding of this EARL8 asic is slightly different from that of SUP720 or RSP supervisors which uses EALR7
These links will give you some information you are looking for....
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11-652042.html#wp9000512
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11-676346.html
HTH,
Madhu
Do you have also links where i can find exemples?
