Cisco Radius help
I have setup aaa on my Cisco 3800 to an IAS Radius 2003 Server. Everything works but I want to configure the IAS to hand the privileges for the user logging in. Any ideas on how to do this?
John Blakley
You'll need to pass the privilege level to the user with a class-attribute. You can select "Cisco-AV-Pair" and for the value, type "shell:priv-lvl=3" or whatever level you have configured in your router. Here's a good site describing the process as well:
http://blog.skufel.net/2012/06/how-to-integrating-cisco-devices-access-with-microsoft-npsradius/
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Thanks, but I am not using NPS, I am still using IAS on Server 2003. I need the Vendor-assigned Attribute number, Attribute format, and Attribute value.
