Router takes ip sla commands but does not recognize track
rick505d3
I have an Cisco 850 router (c850-advsecurityk9-mz.124-15.T17). The router is able to take the following command.
ip route 1.1.1.1 255.255.255.255 2.2.2.2 track 1
It shows up n the running-config
#show run | inc ip route 1.1.1.1
However, it doesn't show up in the routing table. If I remove the "track" keyword from the ip route command, then it works and shows up in the routing table. Although "ip sla" command and its sub-commands work, it seems "track" is not there in the global config mode or even in "show track".
Router(config)#ip sla 1 ?
  <cr>
Router(config)#track ?
% Unrecognized command
Router(config)#rtr ?
Is this expected ?
Rick.
cadet alain
From Cisco Navigator this feature is not available on the 850 platform.
Alain
cadet alain
Alain
Thanks Cadet, had a look too and couldn't find it for the 850 series.
Rick.
