07-05-2014 03:04 AM - edited 03-04-2019 11:17 PM
Hi Guys,
I'm schedule to take the route exam early next year. But I receive an email from pearson that the exam is expiring. Please see email below. I'm a little bit confused , can someone clarify the details below..
We are contacting you to inform you that Cisco is retiring exam 642-902 - Implementing Cisco IP Routing onJanuary 31, 2015. Our records indicate that you are currently scheduled for this exam after the retirement date. You will need to reschedule this exam either on or before January 31, 2015. If you are not able to reschedule this exam before the retirement date, you may cancel the exam and reschedule the replacement exam 300-101 (TShoot).
Please visit www.pearsonvue.com/cisco
Thank you,
07-05-2014 04:28 AM
Cisco upgrade every exams periodically. the exam 642 - 902, which u have scheduled after January 31, 2015 will change entirely and its code also. so they are warned you. please reschedule it before 31/1/2015 or cancel it. After this date its not valid .
kazim
07-05-2014 07:21 AM
Thanks Kazim. What does dis mean - " cancel the exam and reschedule the replacement exam 300-101 (TShoot). " ? What is a replacement exam? On my understanding about Tshoot exam, it's better to take Route & Switch first.
Do I need to accomplish 3 exams for CCNP before January 31, 2015?
Thanks..
07-06-2014 02:43 AM
yes it means Tshoot exam(with new code), it depends on you which u like to take first tshoot or route.
you should ask this question to pearsonvue, they will answer you within 5 working days.
The email you have received reply it as soon as possible.
"Please rate and select correct answer, if post helpful"
