Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco Router 2900 Series problem
Hi Guys
I have the problem regarding router i can not acess the router  cisco 2900 series by using ping command when i do this it display message like requested time out though it is connected with catalyst switch 4500 directly but it can not acessed in network any help regarding this issue will be highly appriciated thanks
balaji.bandi
check the port configuration of the port both side switch and router.
If you have console access for the router which is not reachable, post the configuration and explain which port connect to switch.
BB
now the problem is that router is can not accessed through network when i
do ping the router it displays out of reach and Act Link LED continiously
blinks it is not stable so may be it is running in ROM mode if yes kindly
guide me to solve this issue
Hello
if your sure the switch has an IP address then it could be ping reply is negated - have you tried telnet or ssh to the device sourcing from your rtrs conneted interface?
Kind Regards
Paul
