Cisco Router C892FSP-K9 Migration Product
najamuddin
Please suggest a replacement product exact match of Cisco Router C892FSP-K9 that will be not EOL in coming years?
regards
Najam
DanielP211
Hello!
It really depends on your needs, but if you are looking for a complete replacement (8 switch ports, 2 WAN, SFP port) i would go with C1111X-8P. If you need better performance there are here 1131X, 1161X... You can also add LTE...
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html
BR
****Kindly rate all useful posts*****
