Does Cisco, or anyone else do a cable that will allow me to connect my USB only laptop to a console port on a Cisco device?Thanks
The message you are trying to access is permanently deleted.
I'm trying to configure a HWIC-16A as a terminal server without success. I can get a telnet session to connect, but I simply get a blank screen, no data appears to be sent or received over the serial line.The only similar post I could find was https:...
Hello, Is there a difference between these two cables? A920-CONS-KIT-S, found on this page:https://www.cisco.com/c/en/us/td/docs/routers/asr920/hardware/installation/guide/b-asr920-ic-hig/b-asr920-ic-hig_chapter_0101.html A900-CONS-KIT-S, found on th...
When I try to push my configuration-group template on the SDWAN Cedge device from vManage. I am getting this error in the push logs:Failed to verify appids : dreoptDevice model : 8200-1N-4TCan anyone help resolve this issue?
Security appliances software versions MX 26.1.7 changelog Executive summaryMX 26.1.7 is the first Recommended release in the MX 26.1 release family.We recommend planned, phased production adoption in accordance with normal change-control and platform...
To build an HA setup for the MX appliances, what are the requirements from the ISP side? Specifically, is it mandatory for the ISP to provide at least three IP addresses per WAN circuit to support MX HA, or are there alternative deployment options wh...
Hi all, a few questions for an Auto VPN design reusing existing MX and C8111-G2-MX units:Can two C8111-G2-MXs run as a routed warm-spare pair acting as an Auto VPN hub? Does WAN Uplink Sharing (MX 26.2) support the C8111, and is 26.2 stable for produ...
Hi,I'm looking for some guidance on a specific service side that I'm having issues to get it workingBelow is the requirement.Source IP(Outside Global)Destination IP(Inside Global)SRC NAT(Outside local)DST NAT(Inside Local)200.1.1.110.233.87.224192.16...
For the C1121-8P device, what license(s) do I need to purchase to achieve 100 Mbps IPsec throughput? I have a few questions regarding whether the following two approaches would work: First, if I purchase a DNA Essential license, can I achieve 100 Mbp...
I'm in the process of learning how to build a SD WAN environment with a cluster of vmanage servers and a number of controllers and validators. Right now the setup is strictly an air gapped lab. I have physical c8000 devices I was looking to onboard...
Removed an ISR4321 from service. Trying to login to wipe the config and it keeps going into a boot loop.Initializing Hardware ...Checking for PCIe device presence...%ERROR: Critical device not found on 00:02.00doneSystem integrity status: 0x610Rom im...
Hello, everyoneI understand that EVPN can operate under the following modes:VLAN Based - one vlan -> one bridge-domain -> one EVIVLAN Aware - one vlan -> multiple bridge domains -> one EVIVLAN Bundle - multiple vlans -> one bridge domain -> one EVIMy...
Hello, everyone.With EVPN, is there any reason to set the label allocation from per-BD to per-CE? With per-BD, the receiving PE has to do a forwarding lookup in the corresponding BD to identify the exit ACWhile with per-CE, it immediately knows which...
Hello Cisco Community,We currently have a DMVPN deployment where the IPv4 subnet assigned to the tunnel interfaces is approaching exhaustion. We need to increase the number of available tunnel IP addresses to support additional spokes. We are open to...
I've just deployed a VMx-L in AWS, dashboard is connected fine. I now need to configure it so the subnets inside AWS can see the subnets inside our network we publish using the autovpn. Do I just use a single subnet to a vpc in AWS and then do everyt...
| Subject | Author | Posted |
| 10-29-2026 07:23 AM | ||
| 10-25-2026 05:54 AM | ||
| 10-16-2026 04:12 AM | ||
| 10-14-2026 05:56 PM | ||
| 10-06-2026 04:52 AM |
| User | Count |
| 7 | |
| 5 | |
| 2 | |
| 2 | |
| 2 |
