Cisco Router Hardware Redundancy
NAGISWAREN2
Hi All,
Is there any way to do Router Hardware Redundancy (HA) . My requirement is Active/passive whereby all my WAN link connected to WAN switch, distributed to two Routers. Once Primary router fails, standby router should pickup. All my WAN link is Ethernet base. The Problem is all WAN link comes with /30 IP only. How to achieve this? Is it possible to use HSRP?
Nagis
Regards, Nagis
Hi Nagiswaren,
You must be able to, Plese refer the link below
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_hsrp_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Please rate helpful posts
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
