Cisco router ISR 1111-8p set wan port
Lf379
Hi.
I bought a ISR 1111-8p for testing and i want to set the wan port with this parameters
PPPoATM (or PPPoA or PPP Over ATM);VPI=8; VCI=35; encapsulation VC-Mux (sended me by ISP)
I want to apply these commands taken here
https://www.cisco.com/en/US/docs/ios/bbdsl/configuration/guide/bba_agg_ppp_atm.html
But when i type "interface atm 0", It return error because of atm command doesn't exists, instead atm-acr exists.
Why atm command not exists and how can i do ti set the wan Port of the router?
make the changes marked in bold to your configuration. I made some assumptions regarding the IP addresses of Vlan 1 and Vlan 2, if yours are different, change them accordingly:
Current configuration : 4510 bytes
! Last configuration change at 21:52:51 UTC Fri Jan 10 2020
version 16.9
service password-encryption
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname CISCO1111
boot-start-marker
boot-end-marker
enable secret 5 xxxxx
no aaa new-model
subscriber templating
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
crypto pki trustpoint TP-self-signed-xxxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-xxxx
revocation-check none
rsakeypair TP-self-signed-2511702922
crypto pki certificate chain TP-self-signed-2511702922
certificate self-signed 01
xxxxxxxxx
quit
license udi pid C1111-8P sn xxx
no license smart enable
diagnostic bootup level minimal
username cisco privilege 15 password 7 xxxx
username admin secret 5 xxxxxx
redundancy
mode none
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.2.1
ip dhcp pool VLAN1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
ip dhcp pool VLAN2
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
ip address dhcp
ip nat outside
speed 1000
no negotiation auto
interface GigabitEthernet0/0/1
no ip address
speed 1000
no negotiation auto
interface GigabitEthernet0/1/0
shutdown
interface GigabitEthernet0/1/1
shutdown
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
shutdown
interface GigabitEthernet0/1/4
shutdown
interface GigabitEthernet0/1/5
switchport access vlan 2
interface GigabitEthernet0/1/6
spanning-tree portfast
interface GigabitEthernet0/1/7
interface Vlan1
ip address 192.168.1.0 255.255.255.0
ip nat inside
interface Vlan2
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
ip forward-protocol nd
ip ssh version 2
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
password 7 06555B781D4907
login local
transport input ssh
line vty 5 15
login local
transport input ssh
pnp profile pnp_cco_profile
transport https ipv4 xxxxx port xxx
10 Replies 10
did you configure the controller?
ISR1111#conf t
ISR1111(config)#controller vdsl slot/subslot/port
ISR1111(config-controller)#operating mode auto
Do you have an ATM interface ?
interface ATM0/3/0
no ip address
no atm oversubscribe
no atm enable-ilmi-trap
no shut
interface ATM0/3/0.1 point-to-point
ip address 100.100.100.1 255.255.255.0
pvc 1/38
vbr-rt 400 400
I have only 8 Port GE and 2 Port WAN GE
your model does not support any ADSL/VDSL. You need the 1112-1116 models. Check the data sheet Table 7:
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html
I have a modem dlink and i want to connect the Cisco router to internet through the wan Port.
I can't to find the way to do this.
you need to connect a GigabitEthernet port to the D-Link and set it to 'ip address dhcp'. Then you need to perform double NAT.
Post the running configuration of the ISR so we can fill in the bits and pieces...
ok, with ip address dhcp the router is connected with the internet ( the ping to google.com answer accurately )
Now it needs of the Nat.
This is the show run
version 16.9
hostname CISCO1111
boot-start-marker
boot-end-marker
no aaa new-model
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
xxxxxxxxx
quit
redundancy
mode none
ip address dhcp
ip nat outside
speed 1000
no negotiation auto
no ip address
speed 1000
no negotiation auto
shutdown
shutdown
shutdown
shutdown
interface Vlan1
no ip address
interface Vlan2
ip address dhcp
ip nat inside
router rip
version 2
network 192.168.1.0
network 192.168.2.0
no auto-summary
ip default-gateway 192.168.1.1
ip nat inside source list 1 interface Dialer0 overload
ip default-network 192.168.1.1
ip ssh version 2
control-plane
line con 0
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
version 16.9
hostname CISCO1111
boot-start-marker
boot-end-marker
no aaa new-model
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
xxxxxxxxx
quit
redundancy
mode none
ip dhcp pool VLAN1
dns-server 8.8.8.8
ip dhcp pool VLAN2
dns-server 8.8.8.8
ip address dhcp
ip nat outside
speed 1000
no negotiation auto
no ip address
speed 1000
no negotiation auto
shutdown
shutdown
shutdown
shutdown
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
ip ssh version 2
control-plane
line con 0
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
Also the host are connected to internet. Thanks a lot !!!
Only a step is not clear, not works and i skipped it. This :
interface Vlan1
ip nat inside
it is quite possible that your D-Link router uses 192.168.1.0 as well, so if that is the case, you might have to use a different address space for your Vlan 1...
Yes, dlink router use 192.168.1.0 network. I will use another network address for the default vlan 1.
Thank you.
