Licensing
NathanLKoch
Level 3
Level 3
I am trying to configure a new Cisco Router I purchased on Ebay but before I connect it to the internet I want to get a firewall enabled. My plan was to use zone based firewalling and after I enter "conf t" to create my zones it shows me zone isn't an available command. Is this a licensing thing? I looked over my license info and it doesn't show much. I am trying to figure out how to enable licensing on Cisco Devices. I have three of them I will have to do the same thing with.
NASA#show license EULA
Feature name             EULA Accepted
ipbasek9                 n/a
securityk9               no
uck9                     no
datak9                   no
FoundationSuiteK9        no
AdvUCSuiteK9             no
ios-ips-update           no
SNASw                    no
hseck9                   n/a
cme-srst                 no
mgmt-plug-and-play       n/a
mgmt-lifecycle           n/a
mgmt-assurance           n/a
mgmt-onplus              n/a
mgmt-compliance          n/a
This is a 2911 but I have 2 other devices I will have to configure and do the same with as well.
Is licensing transferable with the hardware based on serial number? How much is the securityk9 package if I need to purchase it? or would I be better off buying an ASA on ebay with sec bundle?
-Nate
-Nate
"Fortune favors the brave."
Georg Pauwen
you probably have right to use licensing. You need to accept the EULA and then activate the license:
The syntax should be something like below:
2911#license right-to-use activate featureset accept EULA
and then reload the router.
7 Replies 7
Georg Pauwen
NASA#show license all
License Store: Primary License Storage
StoreIndex: 0   Feature: ipbasek9                          Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
License Store: Built-In License Storage
StoreIndex: 0   Feature: securityk9                        Version: 1.0
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        License Priority: None
StoreIndex: 1   Feature: uck9                              Version: 1.0
StoreIndex: 2   Feature: datak9                            Version: 1.0
StoreIndex: 3   Feature: FoundationSuiteK9                 Version: 1.0
StoreIndex: 4   Feature: AdvUCSuiteK9                      Version: 1.0
StoreIndex: 5   Feature: ios-ips-update                    Version: 1.0
StoreIndex: 6   Feature: SNASw                             Version: 1.0
StoreIndex: 7   Feature: cme-srst                          Version: 1.0
        License Count: 0/0  (In-use/Violation)
Can I use it as a right to use but not as eval?
You have the right use until expiry.
BB
balaji.bandi
You do not have a License which you purchased, contact local Cisco SE or Partner to assist you for the License buy.
Other suggestion whenever you buy from eBay, make sure you ask show version and show license before buying, so you know better what you buying product have enough feature what you intended to implement in your network.
BB
Yeah, The seller provided screenshots of licensing. It showed none under security. It may have been licensed at one point. I'm not sure. I will have to do some digging. I don't know how licensing works with Cisco. I got a 2900 online for under 100 dollars. Not too bad. I will see how I can get this licensed or I will buy an ASA.
Thank you for your help.
By the way. In IOS 15.7(3)M3.
#license right-to-use move AdvUCSuiteK9
#show license EULA
ipbasek9                 n/a
securityk9               yes
uck9                     yes
datak9                   yes
FoundationSuiteK9        yes
AdvUCSuiteK9             yes
ios-ips-update           no
SNASw                    yes
hseck9                   n/a
cme-srst                 yes
mgmt-lifecycle           n/a
mgmt-assurance           n/a
mgmt-onplus              n/a
mgmt-compliance          n/a
This was how I got the feature set enabled. zone configuration now works.
#show license
Index 1 Feature: ipbasek9
        Period left: Life time
Index 2 Feature: securityk9
        License Type: RightToUse
        License State: Active, Not in Use, EULA accepted
        License Priority: Low
Index 3 Feature: uck9
Index 4 Feature: datak9
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: ios-ips-update
        Period left: Not Activated
        Period Used: 0  minute  0  second
Index 8 Feature: SNASw
Index 9 Feature: hseck9
Index 10 Feature: cme-srst
It's been enabled but not in use? I am confused. Does this mean I don't have to license?
It's a boot variable. I am the learnings.
NASA(config)#license boot module c2900 technology-package securityk9
