VPN Site to Site routing issue
secured2k
I'm no Cisco regular but a client asked me to establish a VPN connection between their sites so I thought, this shouldn't be hard...
Cisco 2900 series at the main site with a public IP address and 172.16.x.x/24 internal net.
SonicWall at the remote site with a public IP address and 10.x.x.x/24 internal net.
I just added the VPN set up and confirm it's connected, but I can't get data to be sent out of the Main site through the VPN to the remote site. I had tcpdump running on a system in the main network and can see traffic (pings, dns) successfully coming from 10.x.x.x to 172.16.x.x, but the return path never completes. Likewise, sending any data out of the main network to the remote never reaches the remote (remote site shows 0 data received over tunnel).
I didn't set up the original config and left much of it alone. I assume an original config is stopping traffic (maybe some NAT rule?) Can anyone shed some light on this?
I've filled out much of the extra config.
version 15.0
no aaa new-model
no ipv6 cef
ip source-route
ip cef
redundancy
crypto isakmp policy 1
 encr aes
 authentication pre-share
 group 14
 lifetime 180
crypto isakmp key [password] address [site2-Public-IP]
crypto ipsec transform-set aes-security esp-aes esp-sha-hmac
no crypto ipsec nat-transparency udp-encaps
crypto map SITE2-MAP 1 ipsec-isakmp
 set peer [site2-Public-IP]
 set security-association level per-host
 set security-association lifetime seconds 2700
 set transform-set aes-security
 set pfs group14
 match address ACL-VPN
interface GigabitEthernet0/0
 ip address 172.16.0.1 255.255.255.0
 ip access-group 112 in
 ip access-group 112 out
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description WAN
 ip address [Site1-Public-IP] 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
no ip forward-protocol nd
ip nat pool OUT [Site1-Public-IP] [Site1-Public-IP] prefix-length 24
ip nat inside source list 111 pool OUT overload
ip nat inside source list ACL-NAT interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 [Site1-Public-IP]
ip route 10.16.1.0 255.255.255.0 GigabitEthernet0/1
ip access-list extended ACL-NAT
 deny   ip 172.16.0.0 0.0.0.255 10.16.1.0 0.0.0.255
 permit ip 172.16.0.0 0.0.0.255 any
ip access-list extended ACL-VPN
 permit ip 172.16.0.0 0.0.0.255 10.16.1.0 0.0.0.255
access-list 111 permit ip 172.16.0.0 0.0.0.255 any
access-list 112 permit ip any any
control-plane
end
OK, so we only had 1 public IP address so I removed the ip nat pool OUT lines and the 111 access-list.
Still missing return traffic/traffic out of the cisco router/vpn.
[Change] - 10.16.x.x clients can now ping 172.16.x.1 router.
[Change] - 10.16.1.x network is now 10.16.119.x/24
[Change] - 172.16.x.x network is now 172.16.119.x/24
Current Problem: 10.16.x.x clients can ping or query dns 172.16.x.x network hosts, but when the hosts reply, the traffic is not leaving the cisco router. Additionally, any traffic starting from the 172.16.x.x network does not reach the 10.16.x.x VPN/network.
Here is a sample of tcpdump on 172.16.x.10's switch in promisc. mode.
[Ping from 10.16.119.154 to 172.16.119.10; shows as request timed out.]
19:50:40.028037 10.16.119.154 > 172.16.119.10: icmp: echo request
19:50:40.028219 172.16.119.10 > 10.16.119.154: icmp: echo reply
[Queried google.com from 10.16.119.154 to 172.16.119.10 - timed out on 10.16.119.154 due to no response received.]
19:51:52.858163 10.16.119.154.60000 > 172.16.119.10.domain: 4+ A? google.com.(28)
19:51:52.877946 172.16.119.10.domain > 10.16.119.154.60000: 4 1/0/0 A iad30s21-in-f14.1e100.net(44) (DF)
19:51:54.867471 10.16.119.154.60001 > 172.16.119.10.domain: 5+ AAAA? google.com.(28)
19:51:54.897351 172.16.119.10.domain > 10.16.119.154.60001: 5 1/0/0 AAAA lga34s14-in-x0e.1e100.net(56) (DF)
20:11:21.919611 172.16.119.10 > 10.16.119.154: icmp: echo request
[Note: No reply]
On 10.16.119.154, (no firewalling) pings and DNS queries time out. From the 10.16.x.x router/VPN peer, incoming packet statistics show no data received from 172.16.x.x cisco router/VPN peer.
What am I missing?
I got it working by removing my original VPN network route and setting it to use the IP of the remote VPN router.
Problem was my ip route was not working on the Cisco router.
Note: This is on Cisco IOS 15.0(1r)M9.
Cause: Gig0/1 option did not work as expected.
no ip route 10.16.119.0 255.255.255.0 GigabitEthernet0/1
ip route 10.16.119.0 255.255.255.0 10.16.119.1
Traffic passes both ways as expected with no issues - clients on either network can ping each other successfully.
10 Replies 10
Francesco Molino
You paste a config but right after you have subnet changes.
Can you please post the new file (attach it as a text file for better readability)? Also what's not working because you said it now pings and then it isn't replying to ping.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Ok I have attached the config with some items filtered of course. I purposely have made this very basic because I'm not a Cisco network person and the small business just wants some really basic functionality.
Also about the pings vs not replying to ping, please see the tcpdump lines and the example below:
10.16.119.154 -> 10.16.119.1 -> VPN Link -> 172.16.119.1 -> 172.16.119.10 (message received, sending reply.)
172.16.119.10 -> 172.16.119.1 -> ???? (Reply never reaches 10.16.119.1 and beyond).
10.16.119.154 -> 10.16.119.1 -> VPN Link -> 172.16.11.1 (message received, sending reply)
172.16.119.1 -> VPN Link -> 10.16.119.1 -> 10.16.119.154 (reply received)
172.16.119.1 -> VPN Link -> 10.16.119.1 (Doesn't work - no monitoring available; can't tell if message was received or reply was sent)
172.16.119.10 -> 172.16.119.1 -> VPN Link -> 10.16.119.1/24 (Doesn't work - can only see pings reaching switch/local lan router)
172.16.119.1/24 -> Internet (All OK)
10.16.119.1/24 -> Internet (All OK)
VPN Link
#show crypto ipsec sa
interface: GigabitEthernet0/1
Crypto map tag: MAP, local addr 25.x.x.200
protected vrf: (none)
local ident (addr/mask/prot/port): (172.16.119.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (10.16.119.0/255.255.255.0/0/0)
current_peer 50.x.x.100 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 4, #pmts encrypt: 4, #pkts digest: 4
#pkts decaps: 317, #pkts decrypt: 317, #pkts verify: 317
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 25.x.x.200, remote crypto endpt.: 50.x.x.100
path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/1
current outbound spi: 0x325BD1E8(844878312)
PFS (Y/N): Y, DH group: group14
inbound esp sas:
spi: 0xC6636D01(3328404737)
transform: esp-aes esp-sha-hmac ,
in use settings ={Tunnel, }
conn id: 2007, flow_id: Onboard VPN:7, sibling_flags 80000046, crypto map: MAP
sa timing: remaining key lifetime (k/sec): (4565063/1387)
IV size: 16 bytes
replay detection support: Y
Status: ACTIVE
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 2008, flow_id: Onboard VPN:8, sibling_flags 80000046, crypto map: MAP
sa timing: remaining key lifetime (k/sec): (4565069/1387)
IV size: 16 bytes
Status: ACTIVE
outbound ah sas:
outbound pcp sas:
make sure the SonicWall mirrors the encryption domain you have configured on the Cisco, meaning that the access lists need to be the same on the SonicWall. Also, make the changes marked in bold to your configuration and post the output of:
debug crypto ipsec
debug crypto isakmp
SR-RTR1#show running-config
Building configuration...
Current configuration : 3220 bytes
version 15.0
service sequence-numbers
hostname Cisco
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name local
redundancy
encr aes
group 14
lifetime 180
crypto isakmp key password address 50.x.x.100
crypto map MAP 1 ipsec-isakmp
set peer 50.x.x.100
set pfs group14
ip address 172.16.119.1 255.255.255.0
--> no ip access-group 112 in
--> no ip access-group 112 out
ip nat inside
duplex auto
speed auto
ip address 25.x.x.200 255.255.255.0
ip nat outside
duplex auto
speed auto
crypto map MAP
--> no ip route 0.0.0.0 0.0.0.0 25.0.0.200
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
deny ip 172.16.119.0 0.0.0.255 10.16.119.0 0.0.0.255
permit ip 172.16.119.0 0.0.0.255 any
permit ip 172.16.119.0 0.0.0.255 10.16.119.0 0.0.0.255
--> no access-list 112 permit ip any any
end
Ok, removed the access-list 112 entries with no change in network access.
I know the VPN is up and established because I can see the IPSec sa status and see the connection active on both VPN endpoints. Also, I can successfully ping from site2 to the Cisco router (and log in with username / password so I know it's the right device).
However, I added
first (and still had network connectivity, then did
and immediately lost all network connectivity. Awaiting on site guys to reboot the router...
I am guessing maybe my problem is my default ip route needs to remain an IP address instead of interface and so does my ip route back to the VPN.
If so, should I use Gig0/0 (Internal IP) or Gig0/1 (External Pub IP) for the VPN route?
! Doesn't work ! ip route 10.16.119.0 255.255.255.0 GigabitEthernet0/1
! Maybe? ! ip route 10.16.119.0 255.255.255.0 25.0.0.200
! Maybe? ! ip route 10.16.119.0 255.255.255.0 172.16.119.1 (or Gig0/0)
This is confusing, is that a typo ?
Typo while masking public ip.
either one should work, although if you do have a static IP address, it is recommended to use that. So:
ip route 0.0.0.0 0.0.0.0 25.0.0.x
should be sufficient. As with regard to no data flowing, it could be an encryption algorithm mismatch, that is why I asked for the debug output.
--> ip route 10.16.119.0 255.255.255.0 10.16.119.1
Just for my information, where is 10.16.119.1 ?
10.16.119.1 is the remote site's router's private address. It seems it is available on the Cisco because of the connected Site-to-Site VPN Connection.
