Cisco router PAT port status closed
Hi Guys,
As you see the below configuration,  I want to be able to access a device  (192.168.1.100) using port 7331 and 7332  from outside the network using the external ip address and port 7331 and 7332. But when I tried to check the port status using online port scanner tool, status shows "closed". Any help on this matter will be highly appreciated.
no aaa new-model
ip cef
ip name-server x.x.x.x
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
controller DSL 0/0/0
line-term cpe
interface FastEthernet0/0
ip address 85.208.x.x 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.20 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 85.208.x.x
ip dns server
ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.1.100 7331 85.208.x.x 7331 extendable
ip nat inside source static tcp 192.168.1.100 7332 85.208.x.x 7332 extendable
control-plane
line con 0
line aux 0
line vty 0 4
16 Replies 16
Do you have any sort of firewall or virusscanner enabled on the machine with IP address 192.168.1.30 ? I googled around and found that TCP ports 7331 and 7332 are flagged as ports that could potentially be used as Trojan or Virus ports.
Can you try and map the inside ports to some port other than 7331 and 7332 ?
Hi George,
Thanks for the reply.
No virus scanner enabled on this machine. I will try another port on sunday as i am out of office now.
