Cisco Switch access port receiving Unknown protocol drops and it is Increasing for every 10 seconds
dakshinaeswar1
Hi All, We have set of PLC/SCADA devices that is connected to the Cisco switch. All those ports are configured with Same VLAN that it has to be. We can ping the switch from layer 3 perspective but all these end devices are not able to communicate among themselves, when checking the switch access port details I noticed "unknown protocol drops " are increasing for every 10 seconds approximately . I reckon this could be the issue here , have anyone faced the similar kind of issue and what methods have been taken to fix the same ?
Below the output of one of the Interface where it shows constant increase in unknown protocol drops
GigabitEthernet1/0/16 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 7c21.0ea0.ad90 (bia 7c21.0ea0.ad90)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input 00:00:01, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:23:34
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
5 minute input rate 34000 bits/sec, 20 packets/sec
5 minute output rate 148000 bits/sec, 124 packets/sec
24892 packets input, 5083284 bytes, 0 no buffer
Received 3773 broadcasts (3725 multicasts)
0 watchdog, 3725 multicast, 0 pause input
177738 packets output, 26083788 bytes, 0 underruns
1178 unknown protocol drops     //Look here//
0 lost carrier, 0 no carrier, 0 pause output
Next out out taken for the same port after 5 seconds approximately:
Last clearing of "show interface" counters 00:24:51
5 minute output rate 149000 bits/sec, 124 packets/sec
26286 packets input, 5368447 bytes, 0 no buffer
Received 3981 broadcasts (3931 multicasts)
0 watchdog, 3931 multicast, 0 pause input
187731 packets output, 27548620 bytes, 0 underruns
1242 unknown protocol drops   //Look here//
checked the port status and all the ports shows Up and running fine but noticed this is weird .
13 Replies 13
Hello
disable cisco DTP
trunk port  = switchport nonnegotiate
access port - switch port mode access
Kind Regards
Paul
The port is access port. So I don't think we have to apply no negotiate .
Any thoughts?
Hello
I usually apply it anyway it any way
are they actually in an administrative mode of access?
sh interface xx switchport
also are these ports running any link aggregation such as lacp or pagp
Kind Regards
Paul
Hi, I ensured the port is access and switchport mode access is applied.
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 610 (610-Aircast-PLC)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: disabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Vepa Enabled: false
Appliance trust: none
Still no luck. I think as one of the members in this post mentioned for catalyst switch profinet protocol is not supported.
Eashwar
I am not really sure what protocol these SCADA devices use, but I think only the Cisco Industrial (IE) switches and (IR) routers support SCADA connectivity.
We are using model "C9200-48P " .Version is 16.12.1 CAT9K_LITE_IOSXE. The end devices communication protocol should be profinet (profinet over ethernet). Any idea if we need to allow this type of protocol in the cisco switch what needs to be done ?
Eashwar
I don't think the non-IE switches support Profinet. The link below describes how to enable it on an IE switch, I don't think there is an equivalent on your Catalyst...
https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie2000/software/release/15_0_2_ea/configuration/guide/scg-ie2000/swprofinet.html#71392
I do saw the same post. But I am really not sure how can I enable it for Catalyst switch.
Eashwar
as said before, I don't think that command is available at all on 'standard' Catalyst switches...only on IE switches.
did you actually try and configure the ports as trunks ?
interface GigabitEthernet1/0/16
switchport mode trunk
Hi, Yes tried that .Still no luck.
Hi @dakshinaeswar1, did you ever figure out the solution? We're have the same devices and are facing the same issue. My understanding is that IE can interact with Profinet and participate, which isn't avaiable in non-IE switches, but regular 9300s should be able to just pass that traffic along, no?
hey. did you ever soulvede your problem. im having the same issue, and im running trunk
