BGP distribute-list vs filter-list vs prefix-list
daniel.tanch
What are the different between these?
distribute-list                  Filter updates to/from this neighbor
filter-list                          Establish BGP filters
prefix-list                        Filter updates to/from this neighbor
Under what situation to use either one of these?
Peter Paluch
Daniel,
The
distribute-list and prefix-list
perform route filtering based on IP network addresses and netmasks of routes being advertised. The
distribute-list
refers to an ACL to match the individual networks and netmasks, while
prefix-list
refers to a prefix list to do this matching. In fact, the use of
for a particular BGP neighbor in a particular direction (in or out) is mutually exclusive, because they both accomplish the very same goal, just using a different route selection/filtering mechanism (an ACL vs. a prefix list). It is generally better to use prefix lists instead of ACLs - they are much more cleaner and more comprehensible, optimized to match networks/netmasks and subnets thereof.
The
filter-list
performs route filtering based on the contents of the AS_PATH attribute - the sequence and values of atonomous system numbers. To do this, you would configure an as-path ACL that contains one or more regular expressions matching the particular sequence of ASNs in the AS_PATH attribute, and apply it to a neighbor and a particular direction with the
filter-list command. With a filter-list
, you do not perform route matching/filtering based on IP addresses and netmasks.
You might also be interested in reading the follow BGP FAQ entry:
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/5816-bgpfaq-5816.html#one
Please feel welcome to ask further!
Best regards,
Peter
5 Replies 5
Peter Paluch
Daniel,
The
distribute-list
prefix-list
The
filter-list
Best regards,
Peter
Very helpfully your explanation, Thanks Daniel!
Hi @Peter Paluch
What if I configured Distribute-list, route-map, filter-list, prefix-list what is the preference order of BGP?
for Ex:
neighbor 2.2.2.2 prefix-list XXXX out
neighbor 2.2.2.2 distribute-list 101 out
neighbor 2.2.2.2 route-map XXXX  out
neighbor 2.2.2.2 filter-list XXXX out
Siva
For outbound updates the order of preference is:
*prefix-list, distribute-list
*filter-list
*route-map
Sorry but to my understanding, you're wrong. Please see:
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/5816-bgpfaq-5816.html#toc-hId--1706354665
By reffering to this document, for outbound updates the order of preference is:
filter-list
route-map | unsuppress-map
advertise-map (conditional-advertisement)
prefix-list|distribute-list
ORF prefix-list (a prefix-list the neighbor sends us)
