Changing MAC address on a physical interace
loiccruchade
Hello everyone,
I need to change the MAC address on a physical interface of my switch.
The command is not aviable in the interface configuration mode.
The switch is model is :
Switch Ports Model SW Version SW Image Mode
* 1 28 WS-C3650-24TS 03.03.04SE cat3k_caa-universalk9 INSTALL
Is it because this modèle does not support this feature ?
Thanks for the help
8 Replies 8
Hello
you can configure a static MAC address mapping to the interface
macaddress static xxxx xxxx interface xxx
res
paul
Kind Regards
Paul
Hi Paul,
Thanks for your help.
Correct me if i'm wrong, but this command is for creating a static entry in the mac address table.
So it says "to join this mac address, go through this interface" right ?
I need the switch to use a specific mac address on this interface because our ISP use mac filtering.
Every traffic not in the specific mac address range is dropped.
Hello
Apologies mis-understood the question
Okay I am assuming this port is a Switchport not a routed port?
What switch type is it?
Res
Paul
Kind Regards
Paul
I t's a WS-C3650-24TS :
As far as I understand, it's a switchport.
I can't create sub-interface.
I'm trying to do something similar, did you ever get an answer to your question?
Matt
I am using a virtual switch, but you can add the mac address directly to the interface:
And here is the output from it's neighbor
Hope that helps!!
Hi Daniel 90,
What model switch are you using? I have a WS-C2960C-8PC-L and that command does not work on the FastEthernet or Gb ports.
I'm running c2960c405-universalk9-mz.152-7.E8.bin but don't think that matters. This looks to only be available on certain virtual switches and routers per the Master Command List Cisco IOS Master Command List, All Releases - m [Cisco IOS 15.5M&T] - Cisco
Please advise if anyone has specifics on what they are using.
Jason
