CISCO UNITY EXPRESS INSTALLATION/SETUP_SM-SRE-700-K9
incognito
hello
1. i have 2900 series router and SM SRE installed on it. i have an issue with installation of cisco unity express (CUE) on SRE Service module. (it's a second problem, about it i'm going to discuss later. Main problem is explained below)
2. physical connection looks like this (see attached image). I just want to install software to SRE module on router via FTP server. So the router's going to act like a host. I did all configuation by this manual http://www.firewall.cx/cisco-technical-knowledgebase/cisco-voice/889-cisco-unity-express-config-part-2.html
in my case config looks like this:
Switch
interface vlan 100
ip address 192.168.100.1 255.255.255.0
interface gigabitethernet1/0/1
switchport mode trunk
switchport access vlan 100
and we have interface VLAN 200, 300, but administrator's laptop and FTP server are on the VLAN 100
router:
interface gigEthernet0/0
no shut
no ip address
exit
interface gigEthernet0/0.100
Encapsulation dot1q 100
ip address 192.168.100.2 255.255.255.0
interface SM1/0
 description Unity-Express-Module
 ip unnumbered GigabitEthernet0/0.100
 service-module ip address 192.168.100.10 255.255.255.0
 service-module ip default-gateway 192.168.10.2
ip route 192.168.100.10 255.255.255.255 SM1/0
At this point, we should be able to ping Unity Express’s IP address:
router# ping 192.168.100.10
Sending 5, 100-byte ICMP Echos to 192.168.10.10, timeout is 2 seconds:
but it's not pingable from both router and switch.
How to solve this problem?
Giuseppe Larosa
Hello incognito,
change the second line to:
service-module ip default-gateway 192.168.100.2 that is in the same IP subnet and it is the actual router IP address.
Hope to help
Giuseppe
Giuseppe Larosa
Hello incognito,
Hope to help
Giuseppe
hello
thank you for the help
it was a typo.
