Cisco WS-C6506-E port-channel load-balance issues
Tarmo L
Hello!
We are dealing with a tricky situation with two Catalyst Cisco devices where one device being Cisco WS-C6506-E and other being Catalyst Cisco 3560G.
Is there any possibility to split the VLAN content/capacity between two 1GE physical interfaces which are merged into port-channel?
Devices are linked together with port-channel, using two 1GE physical interfaces with "channel-group mode on" command.
Problem is that the traffic is being distributed unequally between two 1GE physical interfaces, where one interface has ~600M of incoming traffic and other one has ~940M of incoming traffic. That means the port-channel is 99% full whereas it should be distributing the traffic evenly between two physical interfaces. We are using VLAN's on these interfaces, where almost all of them are Layer 3 VLAN's (multicast routing).
Our Cisco 6500 stats:
  • WS-6506-E
  • Image: s2t54-IPSERVICESK9-M, Software 12.2(50r)SYS3
  • Supervisor board: VS-SUP2T-10G
  • PFC Oparating mode: PFC 4
show channel hashchannel-id {src_ip_addr|dest_ip_addr|src_mac_addr|dest_mac_addr|src_port|dest_port} [dest_ip_addr|dest_mac_addr|dest_port]
Check this hash and see traffic is pass through which port then change hash algorithm until you get equal load between ports member.
Hello!
Unfortunately I seem not to have this command available on my WS-6506-E...
When issuing the "show ?" command, "channel" is not listed as an available command..
Cisco recommends make hash algorithm match in both side of PO.
Is it same algorithm?
check what is configured now
#show etherchannel ?
<1-512> Channel group number
detail Detail information
load-balance Load-balance/frame-distribution scheme among ports in
port-channel
port Port information
port-channel Port-channel information
protocol protocol enabled
summary One-line summary per channel-group
| Output modifiers
<cr>
example :
#show etherchannel load-balance
EtherChannel Load-Balancing Configuration:
src-dst-ip enhanced
mpls label-ip
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
IPv4: Source XOR Destination IP address
IPv6: Source XOR Destination IP address
MPLS: Label or IP
Understand how Etherchannel load-balance works :
https://www.cisco.com/c/en/us/support/docs/lan-switching/etherchannel/12023-4.html
BB
