CISCO3945 Integrated Gigabit Ethernet ports for routing?
jacinto1m
I was wondering if I could use the CISCO3945 Integrated Gigabit Ethernet WAN ports for routing, I need to enable BGP and I was willing to use one of those ports.
Any help is much appreciated.
Jon Marshall
Jacinto
Could you be a bit more specific. When you say "integrated" do you mean the ports that are inbuilt on the router. If so then yes, they are routed ports.
Jon
Jon Marshall
Jacinto
Jon
Hi Jon,
Thanks for your answer, yes that was what I meant, the inbuilt ports in the router.
