Showing results forĀ
Search instead forĀ
Did you mean:Ā
Video freezing on Multicast
nihit-tandon
I am  running multicast on MPLS and the video content is getting freezed can any one let me knw the reasons.
No ping drops observed on the Link , router supports multicast very well !!! Its a 2Mb Link on Radio frequency
Awaiting for your responses pls
Mohamed Sobair
Level 7
Level 7
Hi Nihit,
Can you elaborate more on your setup, are you running SSM multicast ? if you can perhaps provide snapshot or a design showing the source and destination of your multicast stream , it would be better.
There could be a lot of reasons, bandwidth issues , high latency or drops or if the multicast got broken some where in the Network.
Mohamed
Hi Mohamed,
Thanks for your revert , Yes we are using SSM, Sparse Mode at the spoke locations ,Its a 2Mb link on RF,where the video is getting freezed , The ping response to the /30 is absolutely fne, no packet drops observed.
Can you let me know the way to check the case of multicast streams got broken.
Nihit
You can perform one of the following methods:
1- Join a reciever at Spoke location to a multicast group and try to ping it from the Source.
2- perform (mtrace command) from the spoke to trace the reverse path to the source of the multicast traffic using the group you have already joined to an Spoke interface.
Please post the output of the (Mtrace command), it show where the multicast is getting dropped.
Mohamed
