cisco7606s There was an illegal address issue when upgrading the version
xfyang
Hello
Problem Description:
I upgrade the IOS in the process, which has a 7606 device upgrade process in the case of illegal address
There are two other 7606 devices that can be upgraded in the same way. Also I try the following way, but it does not take effect.
Try the following solutions:
Step 1: rommon 3> set loadprog: disk0:c7600s72033-adventerprisek9-mz.122-33.SRE4.bin
Step 2: rommon 4>boot disk0:c7600s72033-adventerprisek9-mz.122-33.SRE4.bin
log:
Router#sh bootvar
BOOT variable = disk0:c7600s72033-advipservicesk9-mz.122-33.SRD5.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
rommon 7 > boot disk0:c7600s72033-advipservicesk9-mz.122-33.SRD5.bin
Initializing ATA monitor library...
loadprog: error - program section linked to illegal address
boot: cannot load "disk0:c7600s72033-advipservicesk9-mz.122-33.SRD5.bin"
Router#dir
Directory of disk0:/
1 -rw- 133391108 Jan 1 2000 03:37:22 +00:00 c7600s72033-advipservicesk9-mz.122-33.SRD5.bin
512090112 bytes total (378691584 bytes free)
What is the reason for this situation, how should be resolved. Thank you
8 Replies 8
Philip D'Ath
Perhaps the image is corrupt.  You could try downloading it again.
Perhaps ROMMON itself needs an upgrade.
Thank you for your reply.
We try to re-use the FTP server to upload a new image, but still the same situation. Also tried to other 7606 devices can use the mirror passed in the past, or can not be resolved.
Have you used this same image on other 7606's?
Do they have the same ROMMON version?
Another possibility is you have a hardware failure.
I find the customer to confirm what. Will ROMMON version is how to view?
I'm not sure once you are in ROMMON.  Before hand "show ver" will tell you.
This is the information that is viewed through "show version"
Router#sh ver
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRD8, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 09-Apr-12 11:31 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRE, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRD8, RELEASE SOFTWARE (fc2)
Router uptime is 3 minutes
Uptime for this control processor is 3 minutes
System returned to ROM by reload (SP by reload)
System image file is "sup-bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRD8.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7606-S (M8500) processor (revision 1.1) with 917504K/65536K bytes of memory.
Processor board ID FOX1606GFGP
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.1, (0x80390021)
CORE: E500, Version: 2.2, (0x80210022)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Last reset from power-on
1 SIP-200 controller .
2 SIP-400 controllers (4 GigabitEthernet)(1 Channelized OC3/STM-1).
1 Virtual Ethernet interface
54 Gigabit Ethernet interfaces
1 Channelized STM-1 port
3964K bytes of non-volatile configuration memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
Do you need any information? I try to find customers to collect, I try to collect. Is there a possible cause of such a phenomenon?
As well as possible solutions Thank you very much for your answer!
This is your ROMMON version.
Do you know the ROMMON version on the broken unit?
It is starting to look like you have a hardware failure.
I would like to ask this version of the destruction of ROMMON unit, the need to see how we do not know here ROMMON information.
If this is a hardware failure, I will try to open CASE for detailed inquiries. Thank you!
