MP-BGP Testsetup on CISCO ASR 903
i need some help by configuring MP-BGP on Cisco ASR 903 Routers.
I have two Routers #Homer  an #Bart they are linked via IS-IS on the transit-network. Each router has Access to the same VRF on differnet Subnetworks in different virtual Subinterfaces (on a ASR Router called Bridge-Domain).
The is-is works fine, the MP-BGP Informations a there but i can not ping from vrf test (10.10.0.0/24) on #Homer to vrf test (10.20.0.0/24) on #Bart.
BGP looks like good?!
Homer#sh ip bgp vpnv4 all
BGP table version is 9, local router ID is 10.0.0.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 65000:10 (default for vrf test)
 *>  10.10.0.0/24     0.0.0.0                  0         32768 ?
 *>i 10.20.0.0/24     10.0.0.2                 0    100      0 ?
Bart#show ip bgp vpnv4 all
BGP table version is 14, local router ID is 10.0.0.2
 *>i 10.10.0.0/24     10.0.0.1                 0    100      0 ?
 *>  10.20.0.0/24     0.0.0.0                  0         32768 ?
config #Homer
hostname Homer
boot-start-marker
boot system bootflash:Image/packages.conf
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable password telent
no aaa new-model
facility-alarm critical exceed-action shutdown
ip vrf test
 rd 65000:10
 route-target export 65000:10
 route-target import 65000:10
ip host Bart 10.0.0.2
ip domain name babsa.de
mpls label protocol ldp
license udi pid ASR-903 sn XXXXXXXXXXXXXXXXXXXX
license boot level metroaggrservices
sdm prefer default
redundancy
 mode sso
controller wanphy 0/0/0
controller wanphy 0/1/0
controller wanphy 0/3/0
transceiver type all
 monitoring
interface Loopback0
 description "*MGMT*"
 ip address 10.0.0.1 255.255.255.255
interface TenGigabitEthernet0/0/0
 no ip address
interface TenGigabitEthernet0/1/0
 no ip address
interface GigabitEthernet0/2/0
 no ip address
 negotiation auto
interface GigabitEthernet0/2/1
 no ip address
 negotiation auto
interface GigabitEthernet0/2/2
 no ip address
 negotiation auto
interface GigabitEthernet0/2/3
 no ip address
 negotiation auto
interface GigabitEthernet0/2/4
 no ip address
 negotiation auto
interface GigabitEthernet0/2/5
 no ip address
 negotiation auto
interface GigabitEthernet0/2/6
 no ip address
 negotiation auto
interface GigabitEthernet0/2/7
 no ip address
 negotiation auto
interface TenGigabitEthernet0/3/0
 no ip address
interface GigabitEthernet0/4/0
 description "testnetz1"
 ip router isis
 negotiation auto
 isis circuit-type level-2-only
interface GigabitEthernet0/4/1
 description "Transitnetz"
 ip address 10.0.1.1 255.255.255.252
 ip router isis
 negotiation auto
interface GigabitEthernet0/4/2
 description "Transitnetz2"
 ip address 10.0.2.1 255.255.255.252
 ip router isis
 negotiation auto
interface GigabitEthernet0/4/3
 no ip address
 negotiation auto
 service instance 11 ethernet
  encapsulation dot1q 11
  rewrite ingress tag pop 1 symmetric
  bridge-domain 11
interface GigabitEthernet0/4/4
 no ip address
 negotiation auto
 service instance trunk 11 ethernet
  encapsulation dot1q 11-12
  bridge-domain from-encapsulation
interface GigabitEthernet0/4/5
 no ip address
 negotiation auto
interface GigabitEthernet0/4/6
 no ip address
 negotiation auto
interface GigabitEthernet0/4/7
 no ip address
 negotiation auto
 description "*** MGMT Vlan 3***"
 vrf forwarding Mgmt-intf
 ip address 10.3.255.233 255.255.255.0
 negotiation auto
interface BDI11
 ip vrf forwarding test
 ip address 10.10.0.1 255.255.255.0
router isis
 net 49.0001.0100.0000.0001.00
 is-type level-2-only
 passive-interface Loopback0
router bgp 65000
 bgp router-id 10.0.0.1
 bgp log-neighbor-changes
 no bgp default ipv4-unicast
 neighbor 10.0.0.2 remote-as 65000
 neighbor 10.0.0.2 update-source Loopback0
 address-family ipv4
 exit-address-family
 address-family vpnv4
  neighbor 10.0.0.2 activate
  neighbor 10.0.0.2 send-community both
 exit-address-family
 address-family ipv4 vrf test
  redistribute connected
  redistribute static
  default-information originate
 exit-address-family
ip forward-protocol nd
ip bgp-community new-format
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
mpls ldp router-id Loopback0
config #Bart
hostname Bart
boot-start-marker
boot-end-marker
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no logging console
no aaa new-model
ip vrf test
 rd 65000:10
ip host Homer 10.0.0.1
license udi pid ASR-903 sn xxxxxxxxxxxxxxxxxxxx
sdm prefer default
redundancy
 mode sso
 monitoring
interface Loopback0
 ip address 10.0.0.2 255.255.255.255
 no ip address
 no ip address
 no ip address
 negotiation auto
 no ip address
 negotiation auto
 no ip address
 negotiation auto
 no ip address
 negotiation auto
 no ip address
 negotiation auto
 no ip address
 negotiation auto
 no ip address
 negotiation auto
 no ip address
 negotiation auto
 no ip address
 description "testnetz2"
 ip address 192.168.2.1 255.255.255.0
 ip router isis
 negotiation auto
 ip address 10.0.1.2 255.255.255.252
 ip router isis
 negotiation auto
 ip address 10.0.3.1 255.255.255.252
 ip router isis
 negotiation auto
 no ip address
 negotiation auto
 service instance 12 ethernet
  encapsulation dot1q 12
  bridge-domain 12
 no ip address
 negotiation auto
 service instance trunk 12 ethernet
 no ip address
 negotiation auto
 no ip address
 negotiation auto
 no ip address
 negotiation auto
 ip address 10.3.255.234 255.255.255.0
 negotiation auto
interface BDI11
 no ip address
interface BDI12
 ip address 10.20.0.1 255.255.255.0
router isis
 net 49.0001.0100.0000.0002.00
router bgp 65000
 bgp router-id 10.0.0.2
 neighbor 10.0.0.1 remote-as 65000
 neighbor 10.0.0.1 update-source Loopback0
 address-family ipv4
 exit-address-family
  neighbor 10.0.0.1 activate
  neighbor 10.0.0.1 send-community both
 exit-address-family
  redistribute static
 exit-address-family
no ip http server
many thanks!
Julio E. Moisa
Have your assigned the interface to the VRF test? BGP vpn will work over MPLS, is the LDP enabled?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
thanks for the fast feedback! i assigned the interface bdi to the right vrf, furthermore MPLS label protocol ldp was enabeld correctly.
i forget "mpls ip" on the transit-interfaces.
It works fine, now.
many thanks!
