Ciscoworks - RME custom report template
acbennyma
Dear Expert,
Is it possible to use Ciscoworks that I can grep the description of of key work "connect to Video Conference" If yes, what items I can choose in Ciscoworks?
interface FastEthernet0/4
description connect to Video Conference
switchport access vlan 328
switchport mode access
paolo bevilacqua
Wrong forum, post in "network management". You can move your post using the actions panel on the right.
Rolf Fischer
Level 9
Level 9
Like Paolo mentioned, you'll get a better support in the NW-Mgmt forum.
If you're looking for the config files: you can find them in the "shadow"
folder, the path depends on your OS (solaris/windows), just google it.
Hope that helps
Rolf
Sent from Cisco Technical Support Android App
