11-21-2006 09:56 AM - edited 03-03-2019 02:46 PM
Does anyone know if there's a command to clear the QoS counters in Cisco router 3725? I've tried looking it up in support area, but couldn't find the answer for it.
Thanks.
hieu
11-21-2006 01:20 PM
Hieu,
You will have to clear the counter on the associated interface.
For instance, if you have QoS running on Fa0/0, clear counter f0/0 should do it.
____
Please rate helpful posts.
11-22-2006 09:16 AM
Thanks Edison. It worked great. That's what I was looking for.
hieu
