cli ' channel-group 0 unframed ' is no longer support?
syjeon
Hi, we are considering migrate new router and found following configuration is not supported in new one.
Current)
NAME: "Two port E1 voice interface daughtercard with Drop & Insert and G.703 on Slot 0 SubSlot 0", DESCR: "Two port E1 voice interface daughtercard with Drop & Insert and G.703"
PID: VWIC-2MFT-G703=   , VID: V01, SN: xxxx
controller E1 0/0/1
clock source internal
IOS: c3825-adventerprisek9-mz.124-6.T7.bin
New one)
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 2", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 , SN: FOC163776H3
XXX003(config)#controller E1 0/2/1
XXX003(config-controller)#clock source internal
XXX003(config-controller)#channel-group ?
  <0-30>  Channel number
XXX003(config-controller)#channel-group 0 ?
  timeslots  List of timeslots in the channel group
Is this configuration is changed new cli or what shoud I do?
paolo bevilacqua
Only G.703 version of VWIC card supports unframed E1. Meaning, you cannot support unframed E1 with the 'new' hardware you got.
However, if you change to 31 timeslots to the other end too, it will wok fine anyway.
Hi Paolo,
Could you give me a proposed configuration to clear ?
As above: configure channel-group for  31 timeslots on both ends.
Hi, Could you plz check following proposed configuration?
controller E1 0/2/0
channel-group 0 timeslots 1-31
